Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V8 (4.6L, 5.4L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 12-31-2007, 04:03 PM
jtubbs is new and has a neutral reputation at this point.
thermostats
ok i been reading about chaning my thermostat from the factory to a 160 or a 180. does anyone have a information about this like what has to be done or any changes thatr have to be made to the ecu so the computer will turn the fans on and off at the right degree?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 12-31-2007, 04:32 PM
phil6608's Avatar
phil6608 has much to be proud ofphil6608 has much to be proud ofphil6608 has much to be proud ofphil6608 has much to be proud ofphil6608 has much to be proud ofphil6608 has much to be proud ofphil6608 has much to be proud ofphil6608 has much to be proud of
From what I have read and herd, you do not want to go below 180.
You should not have to change anything other then the thermostat.
__________________
Phil
DE Chapter Board Member/New Castle County
2003 SuperCrew
DSS Built Lightning block/Stage 3 heads and cams
L-conversion/Kenne Bell upgrade blower at 18 PSI
BTS/4R100 tranny
100 shot nitrous
1.68 60' time/11.76 @ 116.17
TRUE GRIT!
2000 Grand Marquis
JOIN THE DELAWARE CHAPTER, CLICK HERE
  #3 (permalink)
Old 12-31-2007, 04:35 PM
khadma's Avatar
<I really look like this
khadma has a great reputation on FTE.khadma has a great reputation on FTE.khadma has a great reputation on FTE.khadma has a great reputation on FTE.khadma has a great reputation on FTE.
I agree 180 no less.
does that make sense.
__________________
1996 Bronco xlt 5.8,a/t,a/c,31x10.5 BFG's A/T
1999 Ranger supercab xlt 3.0, a/t
1984 Bronco 4.9l, 4spd manual
2002 F150 regular cab shortbox XL 4.2 a/t
1995 Windstar
2007 Explorer XLT 4.0 a/t
1988 Mazda B2200
Member of the Hawai'i Carpenters Union - Local 745
Darren
  #4 (permalink)
Old 12-31-2007, 05:31 PM
rsylvstr's Avatar
Fleet Marine Force Doc
rsylvstr has a good reputation on FTE.rsylvstr has a good reputation on FTE.rsylvstr has a good reputation on FTE.
i asked the same question when i installed the Hypertech Power Programmer III....90% of those out there said, "leave the stock 'stat in....if you do decide to change it, do NOT go below 180"
i left the stock 'stat....she has 99k on the clock, why put her in an early grave!
__________________
Semper Fi,
Rob
HMCS(FMF/AW)
USNR (now)
2001 Ford F150 SCrew Lariat 4 x 4
5.4L 4R70W 3.55 's
  #5 (permalink)
Old 12-31-2007, 07:57 PM
projectSHO89 has a good reputation on FTE.projectSHO89 has a good reputation on FTE.
Just leave the stock in there....
Steve
__________________
Think about it: Ignorance can be addressed through education but you can't fix stupid! ...apologies to Ron White
  #6 (permalink)
Old 12-31-2007, 10:55 PM
LxMan1's Avatar
LxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to behold
The cooler it runs, the more wear you get. The moving parts are designed to be ran around 195 degrees, plus a warmer engine is more efficient and it keeps any moisture burned out of the engine caused by condensation.
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
  #7 (permalink)
Old 01-02-2008, 12:24 AM
ford390gashog's Avatar
ford390gashog has a very good reputation on FTE.ford390gashog has a very good reputation on FTE.ford390gashog has a very good reputation on FTE.ford390gashog has a very good reputation on FTE.
leave the stock one in there. You will start to run into upper cylinder wear issues.
  #8 (permalink)
Old 01-02-2008, 05:13 AM
LastSplash is starting off with a positive reputation.
If you change the thermostat it is a good idea to use one that is the same temp as stock. The ECM will not go into closed loop until the engine/coolant temp gets to a certain temp, if you put a lower temp thermostat in the engine temp may not get warm enough to allow the ECM to go to closed loop which will make your gas mileage go down to about 10mpg.
  #9 (permalink)
Old 01-03-2008, 09:16 AM
thankn guys for all the info the stock one will stay in
  #10 (permalink)
Old 01-04-2008, 11:20 PM
wtroger is starting off with a positive reputation.
Use the stock temp stat if you go to low it will set an engine code and will not go into closed loop.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
