Flathead VS 460
Flathead VS 460
Ok Ryan here goes.
My uncle that is giving me the truck of my choice was telling me he has 2 different 50's flatheads engine, to go in the truck I have my eye on.
I know your partial to these motors, but I want to hear what you all have to say good and bad about them, and what you think about the whole falthead idea, versus the 460 in an old truck idea.
I would love to throw my 460 in the old truck, but more and more I am starting to think about maybe making it more original. Doing something sort of like what Chris has with his truck right now.
All I really know about these flatheads he has is he has two of them, in old grain trucks, and both of them have been rebuilt. One has been rebuilt lately, within the last few years, and the other was rebuilt years ago, then never used.
Received 1,353 Likes
on
on
on
on
It all depends on what you plan on doing with the truck.
Is this just a weekend cruiser with trips under 100 km? Then the flathead will be a great if paired with a 3spd (Pre 53 4 spds suck) and good gears.
If you want to show off or do long trips then the 460 will be better. Just a word of warning the 460 won't be quite a drop in simple deal. You will have to deal the the steering (engine clearance), brakes (transmission mounting and clearance) and the rear axle. It's not as simple as it seems (Don't ask ).
Flathead, if only for the looks. If your going to put in a modern V8, drop the 460 idea, big stupid heavy gas guzzler. If you wanna be diffrent, potentially still make some good power, and have a more modern V8, go Cleveland, or just be like anybody else and 302 it. If you want class and refinement, use a flathead, be creative and hook up a more modern tranny, make it a bit more driveable.
on
Ok lets go on a 2000 budget (ballpark) here is what you would do with a Flattie.
1)- 150-175 hp is very modest and easy for this money without sacrificing torque.
2) use a Chevrolet T5 tranny if you really want to stay Ford I'm sure something from a Ranger would fit, but the Chevy swap is quite common and would be my choice.
3) Ford 9 inch rear end with 3.50 gears on 16 inch 3.25 on 15 inch rubber a Flathead with deuces setup or 4 barrell can handle.
With a T5 setup and proper rear end 110- 120 kmph is very reasonable
There are many tips and tricks to make a Flathead into a modern driver. Two guys that would know better then me in doing this are Chris (effie) and his supplier whoes name is slipping my mind at the moment.
The downsides to Flatheads
1-if you want to leave a patch at every intersection Don't use a Flathead
2- exhaust heats up the coolant in these motors so they run better in winter, bad part with this is that I'm assuming you will never drive it in winter but yet they do get considerabally (spelling) hot. This is not a problem on stock motors or even motors made to push out 200hp, but accesories like A/C and power steering I would use as thoose are always straining the motor.
3- fuel Flatheads were not made to run unleaded so unless you want to change the valve seats it is a good idea to run lead subsitute or 2 stroke oil with your gas as todays gas is too dry. Ask your uncle if the seats were hardened in the rebuild
3B- Flathead even though small motors do use enough fuel, Not as much as a 460 lol so I take it you are not too concerned
4- oiling system ask Chris about it though onb stock motors its fine but I think I remeber him saying something about the filter setup
Flathead motors were one of the most rugged motors built they would run of miles on a litre of oil, but if they blow they really blow.
I'm with First Try in saying if you want modern big don't use a 460 and even though 302 351 is reliable....... big whoop.
