Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator SPONSORED BY:
  #1 (permalink)
Old 12-29-2007, 07:07 PM
al52269 al52269 is offline
Garage is empty, add now
al52269 is starting off with a positive reputation.
P0303 Code - Cylinder #3 Misfire.
Well, while driving home about 2 weeks ago. At speeds of 60MPH or 70MPH
I notice my engine light started to blink several times,
until it stop and staid on. There was some hesitation too.
When I got home, I took my hand held Code Reader and it came
with this code ---) P0303 Code - Cylinder #3 Misfire.
I had this truck for over 3 years now.
I have never had any problems with it.
Other, than blowing the rear differential.
I have never tune it up other than regular oil changes at 3000 miles.
I was waiting until code came back on.
Well it came back on today at the same speeds of 60MPH or 70MPH
It was running so good that it’s even past inspection and emissions on (11/30/07),
with no help what so ever.
I guess it about time something when wrong.
My 1998 Ford Expedition got 120,000 Miles and going strong...
I should just give it a tune up.
I stop at AutoZone and pick up Motorcraft spark plugs at $9.99 each plus tax.
WOW, I didn’t realize they were so expensive.
I didn’t pick wires up due to them look brand new.
I guess I will find out tomorrow morning when I tackle this monster of a job.
Later, Al
(Admin note: Please don't take posts from other sites and paste them here. You end up including their advertising links and causing your posts to be automoderated. A PIA for you, and for us. Instead, make your post in notepad and then paste it from there to both sites.)
  #2 (permalink)
Old 12-30-2007, 06:36 PM
Well, Guys
Here is the update...
I gave up trying to change the plugs.
I will take it to the shop and have them do it.
I couldn't fit my big hand anywhere, unless I took lots of thing apart.
Hell no I rather pay.
Later, Al
  #3 (permalink)
Old 12-30-2007, 09:15 PM
bridge's Avatar
bridge bridge is offline
Displaced Scientist
2011 Ford F-250
My Garage
bridge has a very good reputation on FTE.bridge has a very good reputation on FTE.bridge has a very good reputation on FTE.
So, I guess that years model uses a distributor with spark plug wires and not COPs. If it was COPs I'd say swap the number three out for one of the other 7 and see if you get a misfire on that same cylinder. Although after 120K miles a fouled out plug is definitely a possibility.
__________________
2011 F-250 King Ranch Crew Cab 6.7L Diesel FX4
2006 F-150 Lariat SuperCrew 5.4L 3V 4x4 (I miss u)
2006 EB Expedition 5.4L 3V
2002 Mustang Convertible GT 4.6L
2001 Eddie Bauer Expedition 5.4L
  #4 (permalink)
Old 01-01-2008, 02:28 PM
PerfDistIgnition PerfDistIgnition is offline
FTE Sponsor
PerfDistIgnition is starting off with a positive reputation.
Could be a bad coil pack.
www.performancedistributors.com
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
  #5 (permalink)
Old 01-02-2008, 02:09 AM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud of
Wow, the Motorcraft plugs were only $3.99 at my Autozone.
__________________
Jimmy- FTE Moderator
88 5.0 LX Mustang
63 F100 351W/C6
  #6 (permalink)
Old 01-02-2008, 08:36 AM
You know what's funny is....
It had 98K miles on it when, I bought it around 3 years ago.
I look inside the hood and it looks like the previews owner did some work to it.
I saw new wire and new plugs at the time.
So do you guys think I should still tune it up after 22k miles I put on?
Or could it be a bad coil pack?
And if so how can I find out for sure. Since it only has two coil pack and not eight?
Thanks in advance… Al
  #7 (permalink)
Old 01-08-2008, 05:31 PM
Well, Guys
I was trying to hold on until weather got warmer but it’s getting worst.
Now I’m getting two codes, PO303, PO304.
It feels like it’s running on six cylinders instead of eight.
I had to park it until this weekend; I’m going to try doing it myself.
I shop around and return the Motorcraft spark plugs at $9.99 each from Auto Zone.
And, pick up the Motorcraft spark plugs at $5.00 each at another store.
I have a question? What spark plug wires should I used?
Reminder, I have a 98 Ford Expedition with the 4.6L motor.
Thanks in advance, AL
  #8 (permalink)
Old 01-09-2008, 05:58 PM
ToddRG ToddRG is offline
ToddRG is starting off with a positive reputation.
I'd recommend going with Motorcraft. Should run about $100 for the set.
  #9 (permalink)
Old 01-11-2008, 10:13 PM
Well Guys
I finally got the change to change the plugs and wires. Boy it wasn't easy. It took me 4 hours, due to after putting new plugs in the socket. The socket keep getting stunk on the new spark plug and boy it was a pain in the *** trying to get socket off. I did find a secret weapon, before installing new plug on socket put a small amount of white crease on socket this will help make socket slide out more easily. It works great on #3 and #4 especially since you won’t have a lot of room to work with.
I install Motorcraft Platinum Spark Plugs, and Bosch Platinum Wires.
It runs like new. I also found an article on the installation after I was done with mines. It figures.
How To Change Spark Plugs on 4.6 & 5.4 Liter F-150s
By Dave West
If anyone needs it let me know and I will repost it.
Thanks for all the help…
Al52269
  #10 (permalink)
Old 01-12-2008, 07:12 AM
vze2sgxa vze2sgxa is offline
vze2sgxa is starting off with a positive reputation.
Smile
Like I say in my post on my experience with changing plugs for the first time, you are better off doing it yourself because you will never know if a shop actually changes #4 and #8; only someone who has done the change themselves would know: http://www.ford-trucks.com/forums/68...ml#post5499863
__________________
2008 Escape Ltd 4X4/V-6, 40k as of Feb 2011. (I miss my 2000 Expy - it was a tank ... but it saved me in that accident.)
  #11 (permalink)
Old 01-12-2008, 02:25 PM
fun_suv's Avatar
fun_suv fun_suv is offline
fun_suv is gaining momentum as a positive member of FTE.
My eyes hurt after reading this thread.
__________________
Big Dave 99 Expedition 5.4 4x4
Southern California FTE
  #12 (permalink)
Old 05-11-2008, 09:07 AM
trooper397 trooper397 is offline
trooper397 is starting off with a positive reputation.
Dagnabbit....My wifes Ex is pulling the PO303. I guess I know what I am doing for my vacation.
"How To Change Spark Plugs on 4.6 & 5.4 Liter F-150s" , thanks for the post and link
  #13 (permalink)
Old 07-25-2008, 04:13 PM
knix's Avatar
knix knix is offline
knix is starting off with a positive reputation.
question about this error code, since changing all the plugs is a PITA, could I just change #3 to see if that fixes my problem. and if it fixes it then do a whole plug change.
The whole top end was went thru 20k miles ago, I would thought they put in new plugs at that time. HOW do I know which one is No 3. does it start on the drivers side from front and move 1 to 4 then pass side 5 to 8? or does it horse shoe? or does it start like reading a book, from pass side to drivers side? sorry, but the manual i have just says change plugs, remove all plugs, there are pics of the plugs coming out of the holes without any information on which is considered #1 or 2 or so on. I just had a thought, I need to search these pages to see what the cylinder numbers are, that would tell me where no 3 plug is.
thanks
Knix
found my answer again, thanks
Racerguy
Super Moderator Join Date: Aug 2002
firewall
4 8
3 7
2 6
1 5
rad
__________________
Dave - FTE moderator
Forum Guidelines
Last edited by knix; 07-25-2008 at 05:02 PM. Reason: more questions, and found answers, thanks
  #14 (permalink)
Old 12-15-2008, 08:28 PM
RangerRuss RangerRuss is offline
RangerRuss is starting off with a positive reputation.
Recently purchased Autolite platinum plugs at Walmart $4.42 pair. Best price I've seen anywhere. On my vehicle the problem was a spark plug wire.
Russ
__________________
2002 XL 2.3 Automatic
1998 Contour Zetec 2.0 - RIP 5/7/2009
  #15 (permalink)
Old 09-14-2012, 08:44 AM
gmingrone gmingrone is offline
gmingrone is starting off with a positive reputation.
Spark plugs
I have a 97 Mountaineer and found it's easiest to to access the spark plugs through the fender wells. Remove the front tire and rubber splash guard. Should take about an hour to replace all plugs.
Tags
2001, 2006, 54, 54l, code, codes, cylinder, error, expedition, explorer, f150, f250, ford, misfire, p0303, po303, po304
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
