Anyone using Glowshift guages and pod?
Any one use the pods made by this outfit???? I found new pillar pod and 7 color gauges locally . Wanted to know how they fit before I drive the 50 Plus miles and the pod be a add on instaed of complete replacement . Thanks
They can be found on eBay under glow shift Gauges
__________________
Red Neck rule #1 If you drive a truck you should always be looking for trucks to get parts off of. If you can't find part used you aren't looking hard enough.
94 F150 XLT 4x4 SC LB MAF 302 E4od 3:55 ls rear
MSD blaster coil ,cap rotor ,Fordracing 9mm wires
