Go Back   Ford Truck Enthusiasts Forums > Misc. > Air Intakes, Air Filters & Ram Air
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 12-28-2007, 06:26 PM
jadmt jadmt is offline
Garage is empty, add now
jadmt is starting off with a positive reputation.
Tornado air feedback?
I was going to cut off the horns in my intake today (1989 f250 460) and I discovered the previous owner had installed a couple of Tornado air devices I pulled them out and left the horns in for now to see if that makes a difference. The Torndado air devices have a web site www.tornadoair.com it appears to be snake oil and if anything seems like it would have obstructed the air intakes. Any feed back on these?
  #2 (permalink)
Old 12-28-2007, 07:03 PM
monckywrench monckywrench is offline
monckywrench has a great reputation on FTE.monckywrench has a great reputation on FTE.monckywrench has a great reputation on FTE.monckywrench has a great reputation on FTE.monckywrench has a great reputation on FTE.monckywrench has a great reputation on FTE.
Any device that improves combustion efficiency would raise horsepower. There is good reason you don't see them on race cars.
  #3 (permalink)
Old 12-30-2007, 11:21 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud of
They make your wallet lighter, so the engine has less weight to pull around, thus making the truck faster
__________________
Jimmy- FTE Moderator
88 5.0 LX Mustang
63 F100 351W/C6
  #4 (permalink)
Old 01-05-2008, 01:13 AM
keyul's Avatar
keyul keyul is offline
keyul is a name known to allkeyul is a name known to allkeyul is a name known to allkeyul is a name known to allkeyul is a name known to allkeyul is a name known to all
keyul87
They don't do anything for you besides waste your money. If your looking for one, check around in the dumpster, that's where you'll find them, they are garbage!
__________________
Kyle
82 f150, shortbed, step side, 300I six, 4x4, NP435 4 speed
  #5 (permalink)
Old 01-05-2008, 09:54 PM
MikeB 88's Avatar
MikeB 88 MikeB 88 is offline
2000 Ford Ranger
MikeB 88 is starting off with a positive reputation.
Never tried one, don't believe it works, but Bobby Likus advertises them on his radio show.
__________________
Mike B
1969 ForDor Thunderbird
2006 Dodge Charger (wifes car)
2000 Ranger Regular cab
2.5L with A/C backed up by the 5 speed manual, 2WD.
159,000+ on the clock.
  #6 (permalink)
Old 01-06-2008, 07:45 AM
projectSHO89 projectSHO89 is offline
projectSHO89 is a name known to allprojectSHO89 is a name known to allprojectSHO89 is a name known to allprojectSHO89 is a name known to allprojectSHO89 is a name known to allprojectSHO89 is a name known to all
Quote:
Paid endorsements are usually just that: Paid endorsements.
Doesn't mean the product is good or bad (in and of itself), it just means the check cleared the bank.
Steve
__________________
2001 F250 SD V10 4x4
HVAC FAQs: http://www.ford-trucks.com/forums/75...xpedition.html
Owner's manuals: https://www.fleet.ford.com/maintenan...ls/default.asp
It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt.” - Mark Twain
  #7 (permalink)
Old 01-06-2008, 09:26 AM
MikeB 88's Avatar
2000 Ford Ranger
Steve
How true!!
__________________
Mike B
  #8 (permalink)
Old 01-06-2008, 06:47 PM
"Bobby Likus advertises them on his radio show."
The endorsement of someone without technical background who does not supply proof is a bunch of guano.
  #9 (permalink)
Old 01-13-2008, 01:08 AM
Sycostang67's Avatar
Sycostang67 Sycostang67 is offline
1993 Ford F-250
Sycostang67 has a good reputation on FTE.Sycostang67 has a good reputation on FTE.Sycostang67 has a good reputation on FTE.
I was able to try one for free for a few months, and noticed absolutely no difference in anything at all. It was nice and shiny though, would look pretty cool hanging from the ceiling. You could make a windchime out of it.
__________________
http://www.ford-trucks.com/user_gallery/tmp/159/159207.520.390
1993 F-250 HD XLT Lariat SC 4X4 7.3/5spd ATS WG turbo @ 12psi, 3" DP 4" straight exhaust, 5" stacks, Hypermax cowl induction, IP up 3 flats, DPS stage 1 injectors, GPR LED mod, Pyro/Boost guages-186whp 363wtq @ 10psi
1986 F-250HD XLT Lariat 4X4 6.9/T19, soup bowl mod, straight pipe.
  #10 (permalink)
Old 01-13-2008, 05:44 PM
I could use a couple to hang around my garden in the summer to scare away the crows.....
Steve
__________________
  #11 (permalink)
Old 01-17-2008, 07:54 PM
BChance's Avatar
BChance BChance is offline
BChance is starting off with a positive reputation.
They got a rating of "craptastic" in a Jeep article once.. I'll try to find that one and share it, it was a hilarious beat down...
  #12 (permalink)
Old 01-30-2008, 01:13 PM
straightsixer straightsixer is offline
straightsixer is starting off with a positive reputation.
Have a friend with a 03 f150 4wd, not sure of the motor. But he bought one of these units and he ended up pulling it back off, total waste.
  #13 (permalink)
Old 02-07-2008, 02:27 PM
TheNomad TheNomad is offline
TheNomad is starting off with a positive reputation.
70 bucks for some cheap stamped tin they can bite my shiny metal rear.
I looked in to these things a lil more and they say it does improve mpg but by only a half ah mile to ah Mile they must be crazy.
__________________
79 F-150 Ranger 5.0.
  #14 (permalink)
Old 02-07-2008, 05:34 PM
John K John K is offline
John K is starting off with a positive reputation.
junk and owner is a jerk
They are junk and the company stinks bad, pure and simple.
I had a 1995 Chevy Silverado (forgive me for I have sinned...I have a 2007 PSD now...) and bought one of those junks in about 1996. They had a claim that if you did not see any benefit within 30 days to return it for money back.
I tried it for 30 days, although calendar wise it was about 60. I am in the military and was in the field for 30 of those days so the truck sat and I wanted to give it a fair chance. It did nothing. I called the company and explained why I had it for 60ish days and not 30 and wanted my money back. The guy was a complete jerk. He was the owner. He told me 30 days was 30 days - period.
Only offered to swap it for one for my other vehicle.
I put it in the trash and did not look back. Figured Karma would get him and I would call him Earl.
Thing that irritates me was the company has a lot of Christian verses and chapters they use and this was definately NOT a Christian attitude. Regardless of your beliefs.....heck, they claim the Christianity part. (not a church/no church push - just feeds the experience I am trying to relay).
John
  #15 (permalink)
Old 02-07-2008, 06:25 PM
"I looked in to these things a lil more and they say it does improve mpg but by only a half ah mile to ah Mile they must be crazy."
THEY are smart and rich. If I bought their scam I'D be crazy. Every engine performance parameter is measurable.
"Thing that irritates me was the company has a lot of Christian verses and chapters they use and this was definately NOT a Christian attitude."
What was the customary penalty for False Prophets?
Tags
1999, 2008, air, chevy, dodge, f150, filter, ford, intake, likus, ram, reviews, silverado, tornado, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
