This is getting old.
Well truck has been running like sheizer lately - shakes bad at idle and between 1000-2000 rpm. At higher revs it smoothes out. So I pulled the VC's and checked the injectors. The two middle ones on the pass side arent contributing(sp) as much as the rest. While I was in there I decided to fix the fuel leak in the valley. Took the cannister out and replaced all o-rings with Ford viton rings, also replaced fuel filter. Put it all back together and no-start. Checked all wiring and it looks good. I am getting .20-.30v on the ICP. I think I should be getting .85. New ipr, icp, and fuel pump. I think my batteries are weak so I am going to replace them. I will update after that. Any suggestions till then???
Be on the lookout on ebay for this truck. I am tired of messing with it.
madMatador78
05-13-2014 09:57 PM
Tool'in Hand
13
08-13-2012 06:51 PM
fishmanndotcom
05-03-2006 12:45 PM
