timing an 89 460?
timing an 89 460?
I have a Chiltons manual and it says the timing in my 89 460 efi is factory set and can not be changed, yet I read on this site it can be advanced from stock 10degrees to 14 degrees or so to help mpg and power. does anyone have a detailed description or a site where I can find out if I can set it or not and if I can how to do it? thanks.
Originally Posted by someday
get a timing light...connect it to the number 1 spark plug wire...warm up the engine and then shut off...disconnect the spout, looks like a jumper plug on the distributor wire hareness...start and check timing...loosen bolt at base of distributor to adjust
What is the secret to getting the distributer to move? I loosened up the nut and the disributer still won't budge. It is set at 10 degrres btdc. I tried using a wrench to turn the distrib. but I am afraid to break something as it is tight. Last time I did one of these years ago the distr. was easy to move.
You have to take the dist out to change the oring. Just mark the rotor on the cap before you take it out and then when you lift the dist up and the rotor spins mark where it stops. Then you can put it back in the same place. I still dont understand why it isnt moving. Maybe some corrosion where the dist sits on the block. Keep at it. Youll get it.
Bucky89
06-21-2020 03:27 PM
superman79
03-26-2015 07:47 AM
lorenr
11-17-2005 09:53 AM
