1990 F250 Heater Core - Ford Truck Enthusiasts Forums
Old 12-26-2007, 10:55 PM
NEBFRD NEBFRD is offline
NEBFRD is starting off with a positive reputation.
Replaced my heater core today. It was so easy and cheap. I've seen other vehicles and this was the easiest I've seen.
1990 F250 460 4x4
Old 12-26-2007, 11:01 PM
dixokai's Avatar
dixokai dixokai is offline
dixokai is starting off with a positive reputation.
Good to hear. Was it plugged or leaking? I may have to change mine due to lack of heat. I think it may be plugged, I'm not getting a lot of heat but I need to investigate further before I change it.
Old 12-27-2007, 10:14 AM
someday someday is offline
someday is starting off with a positive reputation.
did mine a couple of weeks ago...fairly simple...my friends vw requires the WHOLE dash to be removed including the hvac unit
Old 12-27-2007, 05:48 PM
My core had a pinhole leak. For what its worth it's only $23 at oriellys. Then you can take in the old one to the scrapyard and get some of that back.
1990 F250 4x4 460
1995 Mustang GTS 5.0 23k miles
Tags
1990, core, f250, ford, heater, replace
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
