aluminium roller rocker
I found on ebay a set of aluminium roller rocker arms,stud mount. 1.65 ratio X 7/16" stud. My questions are did it gona fit on a stock pair of aussie heads or machining is required to instal. What is the difference 1.65 and 1.73 ratio. Also the seller said is not self-alingning , did this mean guide plate ?
stock 335 heads have pedestal-mount 1.73 ratio rockers. to fit stud-mount rockers, machining is required. 1.65 ratio won't open the valves enuf.
I went with scorpion pedestal mount roller rockers (from Tim Meyer). they bolt right on stock heads, are available in the correct ratio and even fit under stock valve covers.
PostMan617
84
08-01-2016 10:24 PM
mckoloum
20
02-27-2015 03:39 PM
DarkWolf40
11-27-2004 02:14 PM
