Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Bronco II
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 12-26-2007, 07:52 PM
staplegun is starting off with a positive reputation.
Electrical Problems - Turn Signals / AC / Blower Motor
I have a really strange electrical problem;
Here are the symptoms:
1. Key in run posistion, engine not running - Turn Signals Work, AC Clutch Engages, Blower Motor works in all posistions.
2. Key in run posistion, engine running - Turn Signals dont work, AC Clutch does not engage, Blower motor does not work.
Any Ideas?
The wiring diagrams I have seen (online, Hayes) suck and don't go into enough detail.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 12-27-2007, 10:53 AM
rebocardo is a splendid one to beholdrebocardo is a splendid one to beholdrebocardo is a splendid one to beholdrebocardo is a splendid one to beholdrebocardo is a splendid one to beholdrebocardo is a splendid one to beholdrebocardo is a splendid one to behold
Most likely a bad $13 ign. cyl. switch, you could try jiggling the key a bit when the engine is running to isolate the problem.
It might be the ignition starter switch ($12), but, I doubt it, it is usually the cyl. because it get sloppy with age and use. If you search the Ranger or Explorer forum, as an example, you will see it is not an common minor problem.
I have changed dozens, if not 100, under Ford's recall in various vehicles. It is a design issue that shows up with age.
  #3 (permalink)
Old 12-27-2007, 11:25 AM
Thanks for the reply. I was leaning in that direction. Is this a dealer item or can I pick it up at a local parts store?
  #4 (permalink)
Old 12-29-2007, 09:48 PM
The problem turned out to be an ignition switch that was self destructing. It came apart once I removed the steering column shroud removed.
Thanks for the help with the problem.
Coming soon - Project Bronco II - Phase 2
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
