AUX inputs on an '05 factory head unit
Old 12-26-2007, 06:25 PM
Tim98TA's Avatar
Tim98TA
Tim98TA is offline
Well, I have an 05 F350 SD that has the factory head unit. I just had a direct connection done for my Sirus radio, installed. When I hit AUX, on the head unit, I see there is actually 2 options that come up. Push AUX once and it says PIE, and if I push AUX again, it says CRYSTAL LINE. They both play the Sirus when pushed, so I'm not sure whether or not there are 2 different inputs or not. I would like to be able to plug in an MP3 player as well.
Anyone know if this is possible with the factory head unit? Are there 2 AUX inputs on the rear of the head unit?
Old 12-27-2007, 12:00 AM
fordfan28's Avatar
fordfan28
fordfan28 is offline
I don't know the answer, but a friend has an 05 Mustang and he said his does the same thing. He found some information on Mustang Specific searches. I just can't remember what he specifically found. If he lets me know more, I'll post it.
Old 12-28-2007, 06:52 AM
Tim98TA's Avatar
Tim98TA
Tim98TA is offline
Anyone out there know?
Old 12-28-2007, 08:42 AM
FTE Trigger's Avatar
FTE Trigger
FTE Trigger is offline
The factory aux connectors wouldn't be anything the avg. consumer could plug into (using their own personal equip) w/out some interface devices.
On Edit:
Check out Kenwood p/n: KOS-V500 or KOS-V1000; lets you keep your Factory h/u but at the same time connect Multiple aftermarket devices. Iirc... the only stipulation was that your radio had to have the RDS function (haven't tried one w/out RDS).
Peripheral also has a interconnect but you will lose function of the Sat. radio.
Old 12-28-2007, 09:41 AM
Tim98TA's Avatar
Tim98TA
Tim98TA is offline
What is the RDS?
I alrerady have an interface plugged into the headunit now. It is hooked to my Sirus, and I want to be able keep it linked through the head unit and add an MP3 player as well.
Old 12-28-2007, 10:13 AM
FTE Trigger
Radio Data System... its a feature that allows you to see the broadcast info of radio station and artist info (etc.) on the radio display.
On edit: I relized you have the Aux button already... I know that was another stipulation of the Kenwood set-up. I think the RDS req'ment was only to use Ipods and such to see artist/song info on the radio screen.
Old 12-28-2007, 10:24 AM
Tim98TA's Avatar
Tim98TA
Tim98TA is offline
So does it look like there is another input on the back of the head unit?
As I mentioned before, I push the AUX button once and 'PIE' comes up, with 'dvd' below that. If I push it again CRYSTAL-LINE' comes up. It appears that there may be 2 AUX inputs on the back, but I want to confirm that.
Old 12-28-2007, 11:02 AM
FTE Trigger
Do you know which interface as far as p/ns?
If we know this we can determine What that interface has on it already. (if it came with 1...2 4 6 Connections)
Old 01-01-2008, 09:51 PM
Tim98TA's Avatar
Tim98TA
Tim98TA is offline
It's a PIE unit. I'll have to call the place that installed it for me and ask them.
Old 01-03-2008, 06:44 AM
Tim98TA's Avatar
Tim98TA
Tim98TA is offline
Found out, I have this unit.
http://www.logjamelectronics.com/piefrdnauxs.html
In order for me to get an extra accessory hooked to it, I'll have to hook this unit to it.
http://www.logjamelectronics.com/soundaux3.html
Old 01-14-2008, 09:11 PM
Citypol86's Avatar
Citypol86
Citypol86 is offline
I have an '05 F250 with the CD-6 six-CD changer in the head itself. Before I pull my dash apart, does anyone have a picture of the rear of this unit? All I want is a simply 3.5mm plug-in for my non-Ipod mp3 player. I already have the "AUX" button and nothing else plugged into the head. Is something like Tim98TA's adapter what I'm looking for?
Thanks,
Later...
Brewster...
Old 01-14-2008, 10:42 PM
Beerstalker's Avatar
Beerstalker
Beerstalker is offline
No, you need this one.
http://www.logjamelectronics.com/piefrd04aux.html
Then you will just have to get a cable that has RCA jacks on one end, and a 3.5mm stereo jack on the other end.
ruhuntn
1999 to 2016 Super Duty
07-17-2012 11:38 PM
jv-10
01-04-2009 09:32 AM
jfboy
02-28-2008 12:38 AM
FloridaF250
02-01-2008 11:14 AM
rickauf
17
07-28-2007 04:06 AM
Quick Reply: AUX inputs on an '05 factory head unit
