300 rich on a hot day
Old 08-10-2000, 08:22 PM
dillon's Avatar
dillon
dillon is offline
Old 08-17-2000, 11:04 PM
Hammer@'s Avatar
Hammer@
Hammer@ is offline
I have a 93 F150 4X4 300, E4OD. The truck starts fine, after putting in gear and rolling approx. 50 feet, will die. It is then hard to start, and once started, lots of black smoke, and cannot be accelerated without dying. This continues until reaching running temperature. After a 30 minute drive, gas is being pushed out of the front tank filler neck. The code from the check engine light is 179, which indicates system rich. I have replaced the oxygen sensor, fuel pressure regulator, and map sensor (the last two suggested by a Ford mechanic). I'm not convinced the problem has been solved, and if anyone has had a similar problem, I would appreciate any information.
Old 08-18-2000, 09:39 AM
PAUL_2's Avatar
PAUL_2
PAUL_2 is offline
Since your problem seems to be temp related , has the Ford tech checked the resistance of the coolant & or air temp sensors ? These two sensors also control the mixture . The O2 only goes to closed loop operation when it has warmed . Connect a Dvom to both sensors and measure their resistance , cold they should read in the 24 to 37 Ohm range & at operating temp they both should be in the 2 to 3 Ohm range . A continued rich operation like you have described is going to be hard on the convertors .
04-13-2004 12:08 AM
11-12-2002 01:38 AM
01-14-2002 09:06 AM
03-11-2001 10:13 PM
Quick Reply: 300 rich on a hot day
