Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1947 and Older Ford Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 12-26-2007, 01:28 PM
Cool32 is starting off with a positive reputation.
What steering/suspension/brakes options are available for 1946?
I'm looking for steering/suspension upgrade options for a '46 Ford truck. I'm not interested in lowering the front end, just adding normal upgrades such as discs and power steering. I did some searches, but only found info on post-'48 models.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 12-28-2007, 06:43 PM
loholland is starting off with a positive reputation.
I know what you are going through trying to find suspension parts for your truck, I had the same problem with mine, however after some research I found the frame width on both ends are the same as the 48, the 48 is longer in the front past the core support. So, I purchased a IFS MII for a 48 and it fit my 46 ok. also a suspension kit for the rear that fit also, you need to set the front cross member on the centerline of the front axle. There also are disc brake upgrades for the straight axle for the 48 that will also fit the 46-47. Look at some of the hot rod shops on the net. Go down to the news stand and purchase a copy of Classic Trucks Mag. Its full of ads for such things.
  #3 (permalink)
Old 04-19-2008, 08:04 AM
wangshowz is starting off with a positive reputation.
For the straight axle. front disc brakes got Engineered Components, Inc. - Hot Rod Brakes and Brackets - Your One Stop Brake Shop!
  #4 (permalink)
Old 04-19-2008, 11:02 AM
46yblock is starting off with a positive reputation.
I used single leaf springs for the front from Sacramento Vintage Ford. They said the springs were for 48-52 F-1s, but like Loholland indicated, fit the 46 fine.
There are quite a few options on front brakes. Mine are discs by Wilwood purchased from Speedway.
__________________
1946 1/2 ton with 305 cu in Y-block
1990 Ranger 4WD
  #5 (permalink)
Old 04-28-2008, 05:41 PM
COMPLIT1107 is starting off with a positive reputation.
I installed a Fatman Fabrications IFS in a 47 jbar. It worked out really well, however just a little pricey (~ $2k drum to drum with MII Power rack) I have pics of the install at if you have any interest.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
