You can remove one of the tow hooks and replace it with a receiver tube welded to a piece of stout plate. I have used this approach on several of my fleet since they are too heavy to push when we get them hung.
We use the front receivers as winch hard-points.
On the '08 we had to grind off hook off the spacer plate, but the install was much easier on the earlier models.
