1991 F250, Divorced NP205/ZF-5spd...Pics.
I'm in the middle of a 2wd to 4wd conversion on my 1991 F250 supercab (7.3L/E4OD). So far I have installed a kingpin style D60 front axle from an 89 F350 4x4 using the stock F350 front suspension with 2" of extra arch in the springs and a 3rd leaf added. I used 4" F350 lift blocks in the rear and a Rough Country steering stablizer kit up front. It took me and the old man a weekend to do the swap....A lot of work.
Next up I have a pair of 2wd diesel ZF-5spd's and a divorced Ford NP205 t-case to go in with two new Spicer 1350 series yokes for the 205. I want to take out the E4OD now while it works good, is worth some cash and to gain a little more power with the manual gearbox. I have a tilt column and pedals for the swap as well along with a single mass flywheel and all the required parts.
Does anyone here know of any sites or people I could contact that have put a divorced case in an 80-96 F-series???....I have a design in mind using 1/4" wall 2" square tubing but I would be interested in seeing other idea's.
Manwith3fords
06-13-2009 03:51 PM
argoth66
12-30-2008 11:44 PM
Manwith3fords
02-19-2008 03:28 PM
