help me please
#32
#33
on
#34
#37
on
To test the injectors and GP without pulling the valve covers here is what you do.
Each valve cover has 2 connectors each. Each connector has 5 pins once you unplug the harness.
The pins are like this
1 2 3 4 5
1 and 5 are the glow plugs. with your ohm meter put the negative lead on the negative battery terminal and the positive lead on one pin at a time. You reading should be 5-10 ohms for good GP's. hopefully closer to 5 ohms. over that or "out of limit" you have bad wiring or a bad glow plug.
To test the injectors you put the negative lead of the meter on pin 3 and place the positive lead on either 2 or 4. With good wiring and a good injector soleniod you should have around 3.5 ohms. Pin #3 is common to both injectors that why you don't need to move it. If you have higher than 3.5 ohms you have bad wiring or a bad injector.
But I must say that if all 4 cylinders aren't firing you are more than likely looking at an IDM. if you have any friends that have a PSD just swap IDM's with them to test it. 94.5 to 03 IDM are interchangeable though not the same.
1 2 3 4 5
#38
TJ, just for clarification on map sensor issues, when at idle if its bad and you UNPLUG it, what is supposed to happen? Supposed to be better worse, or the same?
And secondly, if the map sensor is good, and you unplug it, what happens? Better worse, or same? I get this confused everytime.
#40
update guys
ok i got another 96 psd out of a junkyard with a bad transmission with 310k. and it runs. i swapped the uvch i suspected was bad. made no difference. then i swapped the "driver injection module" and still it made no difference. sorry its been so long since ive replied but works been crazy. im stumped guys i need your help
#41
on
1 2 3 4 5
1 2 3 4 5
#42
#43
#44
guys, this ohm meter im hain trouble understanding. something that might help me, is there a usuall place these particular wires rub through? from what you guys have experenced or hear about? if i cant find it(which i havent looked yet). i'll have to figure this ohm meter out. thanks again guys!
#45
