Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 12-24-2007, 05:51 PM
seizure911 is starting off with a positive reputation.
truck won't stop starting
My truck seems to be backwards this winter. Every once in a while, the truck starts, but alternator stays engaged. I can turn the key off and the engine shuts off, but the starter keeps turning over the engine (even with the key out).
A new starter relay didn't help. The starter is maybe 2 years old. I am guessing there is some problem in the key switch?
If the starter won't disengage, will pulling the small wire off the relay stop the starter and leave the engine running?
__________________
'93 F250HD XLT 4X4 7.3 NA, ZF5, 4.10's, 265/70-16 bfg at's summer, 235-85-16 studded hakkas winter, gear vendors od
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 12-24-2007, 06:02 PM
Dave Sponaugle's Avatar
Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.
Sounds like the key is not returning to the run position.
Removing the small wire from the solenoid should stop the starter from cranking.
But as fast as I say that, I also have to say there is a second solenoid mounted on the starter that may be stuck if you have a Mitsubishi starter.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #3 (permalink)
wiccantoy is starting off with a positive reputation.
sounds like the solenoid is bad and not bring the starter shaft back. id send the starter back. ive had my starter in for about 1 year and it is starting to have problems. it wont fully engage all the time , sorta like if you had a tooth missing on the flywheel. its the next fix on my list. plus if you get a starter and it still isnt fixed you can just take it back and tell the store it is the wrong one and you dont want it anymore
  #4 (permalink)
Old 12-24-2007, 06:47 PM
You guys are probably right, it is a mitsubishi starter with a second solenoid. I'll try pulling it and getting a new one.
__________________
  #5 (permalink)
Old 12-25-2007, 05:06 AM
Before I went that route, I would unplug the small wire on the solenoid and check to see if it is a key issue.
The rod that runs down the steering column and activates the switch is known to have a few problems.
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
  #6 (permalink)
Old 02-17-2008, 05:12 PM
cletus_the_red's Avatar
cletus_the_red is starting off with a positive reputation.
my 86, and my 87 f-150 did the same thing, i got mine to stop by hitting the starter relay with a wrench before i got new ones.
__________________
1979 460 engine (currently going into my 86)
1986 F-150 4x4 4 speed long box
1987 F-150 4x4 4 speed (Granny low) long box with a 1993 front end, doors,and box.
Check out my gallery if you want to see them
  #7 (permalink)
Old 02-17-2008, 08:02 PM
It was the starter. Probably the solenoid on top of the mitsubishi starter was bad, as you guys suspected. thanks for all the advice!
__________________
  #8 (permalink)
Old 02-17-2008, 11:54 PM
typefour is starting off with a positive reputation.
If your batteries get low the higher current will weld the contacts in the starter. WHen I worked in the auto electric shop that was very hard to explain to customers.
__________________
91 f 350 cc 4x4 zf 5, 7.3 ats intercooled with 6.0 IC all gauges ignored with good aftermarket ones. Head studs, balanced . 12 psi 1k pyro under load way better mileage than the 460.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
