Door Panel vinyl/leather attachment - Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Old 12-24-2007, 01:00 PM
dadbrough dadbrough is offline
dadbrough is starting off with a positive reputation.
My daughter has a 2001 Ford Escape. The small panel insert around the door handle has the vinyl/leather coming off. How do I remove this without taking the whole door panel, the large one covering the window, off?? Any help would be appreciated. I do know what I have to do to reattach this fabric, just cant seem to get teh small panel to come off. Thanks
Old 12-24-2007, 09:31 PM
Nitramjr's Avatar
Nitramjr Nitramjr is offline
Nitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant future
Hey dadbrough,
Welcome to FTE. I have an '05 and a '06 so I am not sure they are the same. If you haven't figured out how to get it off by tomorrow, I can take a look at one of mine and see if I can figure it out.
Shouldn't matter but which door?
Old 12-25-2007, 03:46 PM
its a 2001, drivers side door. its the small panel right around the inside door release.
Also meidcally retired USAF member of 22 years
Old 01-02-2008, 08:33 AM
1978Crew 1978Crew is offline
1978Crew is starting off with a positive reputation.
I pulled the whole door pannel on my Gfriend's 2001 and the covered pannel does not detach form the back. She has the same problem with the leather/ vinyl comming loose. I am just going to try to glue it back on by pulling the entire door panel and working on the insert in place. I would like to find that the insert will pop out, but I have no evidence of that at this point.
Old 01-14-2008, 07:26 AM
Door Panel
I just found i had to remove the whole door panel, then looked to find that the insert panel DOES NOT come loose has to be glued back on while in place. Thanks for the help though
Old 02-07-2008, 02:57 PM
hingabo hingabo is offline
hingabo is starting off with a positive reputation.
I had the same thing on my passenger door. Dadbrough is right, it's all one panel. I used some spray adhesive (masked of the rest of the door) to re attach the vinyl. Probably didn't last 2 weeks before it was loose again. The problem is in the layer of thin foam that gives up. There's no gluing foam to foam so I'll most likely have to find some replacement vinyl or fabric (custom!) to solve it for good.
Old 02-08-2008, 03:07 PM
did you "sand", or rough up the foam before you applied the addhesive? I am needing to do the same, but thought a fresher serface on the foam is needed.
Old 03-16-2011, 07:11 PM
kymagred kymagred is offline
kymagred is starting off with a positive reputation.
We have a 2005 Escape and two doors have the same problem. Talked to the dealer today, was told to call the home office at Ford.
Old 03-24-2011, 09:36 AM
I called Ford, asked for a call back, no call yet!!
Old 03-25-2011, 04:27 PM
All who has or has had this problem needs to call Ford. If Ford gets a lot calls about this they just might do something about it. 800-392-3673
Old 09-11-2011, 09:34 PM
FRDTRUKTUF FRDTRUKTUF is offline
FRDTRUKTUF is starting off with a positive reputation.
Retucking the leather/vinyl inset panel on door
I corrected this today on my 2000 F-150. Did not remove door panel as the posts that I had referenced here indicated that removal would not have helped.
My vinyl "untuck" was isolated to the top edge of the passenger side door.
You will need an ALL PLASTIC PUTTY KNIFE. The one I used had a 3-4" blade, but again the blade and handle are all one piece - molded (moderately flexible) plastic. To be safe, I sanded down the outside corners of the blade, just enough to knock off the point.
Working from the center of the area that needs retucking, align the blade on top of the untucked vinyl, wedging along the edges of the two panels.
Slowly & firmly press the blade down, reseating the vinyl between the two panels.
Working from that spot, work to the left, repeating the process ... and to the right. You can continue process until all of the vinyl is retucked.
The tool left no marring or cuts. I would guess if you needed to work a tighter radius, you may want to use a smaller blade - maybe 1".
Old 09-12-2011, 08:44 PM
aj7885 aj7885 is offline
aj7885 is starting off with a positive reputation.
I used putty knife to loosen trim fabric, I then cleaned up both halves(door and trim). I used contact cement on both halves, let them sit till slightly tacky, and then applied trim back to door panel. Did all this with panel on car, and it still looks good three years later.
Old 09-16-2011, 09:46 PM
scott91370 scott91370 is offline
scott91370 is gaining momentum as a positive member of FTE.scott91370 is gaining momentum as a positive member of FTE.
Quote:
Very doubtful they will do anything for a bunch of vehicles that are 6-10 years old when it comes to a 'small' problem like vinyl coming off the door panel.
Mine has started doing this on the passenger's door (2004 with 220k miles). I haven't taken it off yet but on other vehicles that I have done interior on it is about a $5 job to fix. You just have to tkae your time and use good glue.
Old 09-17-2011, 11:55 PM
db_tanker's Avatar
db_tanker db_tanker is offline
db_tanker is starting off with a positive reputation.
IT just so happens this happened to our 2005 Limited. lol
would a scraper or a brush be better for getting the foam like crud off the panel?
I was thinking a stiff plastic bristle brush and a shop vac to keep the stuff from flying...get a good, rough surface to let the glue adhere to I am thinking.
Old 10-08-2012, 04:54 PM
jfre002 jfre002 is offline
jfre002 is starting off with a positive reputation.
2003 ford escape door trim falling off
AJ 7885 mentioned using contact cement..... Any particular brand? Does anyone have any other suggestions on a particular brand/product of glue to use? My 2003 Escape (leather interior) front passenger door has this issue. I had to tear the whole piece off and trash it. Where can I find a reasonably priced replacement piece (other than Ford dealer or website). What is the professional part name for this piece of trim (for ordering purposes)? Thanks for any and all help on this subject!!!
Door Panel Upholstery Suprawill1 Escape & Escape Hybrid 11 11-11-2016 06:48 AM
xlt door panel - brown burlwood vinyl material art vandolay 1973 - 1979 F-100 & Larger F-Series Trucks 0 09-23-2016 09:37 PM
Question for anyone that has used interior Vinyl srpay paint CountryBumkin 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 25 02-09-2016 08:19 PM
custom door panels kalebc2 1973 - 1979 F-100 & Larger F-Series Trucks 5 12-23-2015 08:34 PM
Marker pen stains on Leather seats. tbr3345 1997-2006 Expedition & Navigator 8 08-26-2007 09:50 PM
Tags
door panel foam
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
