10-18-2000, 10:50 AM
Carb ID on 67 F250
Since your truck is a 67, the carb is probably a Carter YF 1 barrel. I've had four trucks, 68, 69, 81, 90 with the 300 I6 and the earlier three year models all had the Carter YF carb. If you've got other wheels, just take the carb off and take it to the parts store with you, or shoot a picture with a digital camera and take that with you. If your truck has manual choke, and it probably does, you have one of the easiest Carter carbs to rebuild...you won't have to fool with the auto choke and assembly. When you rebuild the carb, take you time and go slow...it's not a complicated process with this carb and it'll do wonders for you truck's performance.
