Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty & Heavy Duty
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Super Duty & Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
  #1 (permalink)
Old 12-24-2007, 12:41 AM
Cecil_Stringer's Avatar
Cecil_Stringer Cecil_Stringer is offline
Garage is empty, add now
Cecil_Stringer is starting off with a positive reputation.
2003 F250 4x4 - Front Lockers Question
On a 2003 F-250 4X4.... when I shift the vehicle into 4 wheel drive (on the dash), do I need to lock in the hubs?
Or does it do it electronically?
Or does the vehicle NOT have the ability to "Lock-In" the front?
Thanks in advance.
  #2 (permalink)
Old 12-24-2007, 01:14 AM
wlihntr's Avatar
wlihntr wlihntr is offline
wlihntr has a good reputation on FTE.wlihntr has a good reputation on FTE.
it locks the hubs from the dash ( it has auto hubs) and you are in 4WD...but it is not a locker .
__________________
2001 Powerstroke, CC,SB,Lariat,Auto,4X4
Mods. in Gallery
2007 Lincoln MKZ awd
http://www.ford-trucks.com/user_gall...oid=65664&.jpg
its good to have an open mind...but not so open that your brains fall out
  #3 (permalink)
Old 12-24-2007, 01:23 AM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32 weekendwarriorfsw32 is offline
Master of Strokes
2004 Ford Excursion
My Garage
weekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud of
Yah you dont have to get out
__________________
Nick PAA#9
08 F-450 KR 6.4 Elite Race Trans, Elite 71mm turbo, ARP, RDP I/C Boots, 5.5 Icon lift, 22.5 AF Independence wheels, OUO
04 X 6.0 Powermax, ARP studs, MBRP, RDP I/C boots, SCT with Inovative, 14.0@96.4MPH
01 X 7.3, Dp, Cass 238/80 Hybrids, Terminator Dual pumps, TNBB, TE thermostat, ARP studs, Fluidampner, RDP 6637, RDP boots *** Big Thanks To RiffRaff Diesel Performance ***
  #4 (permalink)
Old 12-24-2007, 01:29 AM
biz4two's Avatar
biz4two biz4two is offline
biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.
Arrow
If your SD has not had any mods and is OEM...then what you have is ESOF (electronic shift on the fly). The hubs should have an "Auto" and "Lock" setting. While in "Auto"...and by turning the switch to 4Hi or 4Lo...a vacuum actuator sends a pulse to the front hubs and engages them. At the same time...an electronic motor shifts the transfer case into 4Hi or 4Lo (whatever you selected on the switch).
You also have the ability to manually set the hubs to the "Lock" position.
Hope this helps...
biz
__________________
2012 FORD F250 SD CC 156" Lariat FX4 6.2L BOSS 4x4 4.30s
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s -- Traded
1976 F150 LWB Custom 4x4 390FE NP435 3.50s
  #5 (permalink)
Old 12-24-2007, 02:14 AM
If I shift electronically AND MANUALLY lock in the hubs, is there any benefit?
I ask because it tends to only spin 1 wheel up front when I get into a jam.
I would have thought that the front would "lock".
Is this NOT the case?
  #6 (permalink)
Old 12-24-2007, 03:45 AM
Jim59 Jim59 is offline
Jim59 is gaining momentum as a positive member of FTE.
When those front locking hubs are "locked," you are locking the tire/wheel/brghub to the front axle.
Operating the locking hubs manually only help if the automated ESOF system is failing to operate the locking hub. Also, IMO, it is not a bad idea to occasionally manually lock them to spin the components without having to drive in 4 wheel drive.
But, the front differential is a normal open differential ... it is not a "locker." So, you can lose traction and only have one tire spinning away up front.
  #7 (permalink)
Old 12-24-2007, 10:31 PM
Thanks Jim!!!
  #8 (permalink)
Old 12-24-2007, 11:53 PM
oltrucker oltrucker is offline
oltrucker is starting off with a positive reputation.
there is a differentual locker you can get for the front axle that is locked electriclly. i would use one of them, a locker in the front isnt a good thing when you are driving up hill and it engages when you dont know it. if the front tires start spinning you will go straight off the road. but being able to control when the front differential is locked in, you wont have this surprise.
Tags
2000, 2003, 2004, 4x4, axle, diesel, duty, f250, ford, front, hub, hubs, locker, lockers, locking, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
