11-09-2000, 06:46 AM
Exhaust gas coming from the air pump
That is supposed to attach to your exhaust manifold, right before the catalyic convertor. Might be hard to see, but it's tucked up there on the top. You will see a "pre-cat" chamber. The air pump hooks to the upper back of that (If it's the same from my '84'). If the tube is missing, then that is where your exhaust fumes are coming from. I'm told that is supposed to add air to the exhaust fumes to allow the cat to burn more stuff off. IL6's are to have a bad breathing problem, & need lots of air. Guess this was Ford's easiest fix.
Good Luck
Walter
