Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Escape and Escape Hybrid
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 12-23-2007, 10:28 AM
MrsChameleon is starting off with a positive reputation.
Cool Reprogramming auto-theft
Okay, battery got low and car wouldn't start. I bought a new battery and still nothing but the auto theft is flashing. I bought this truck used a few months ago; its a 2005 Escape V6 and it came with only one key. I called one of the Ford dealerships service department and they said I would need to have the truck towed in to have the auto theft reprogrammed. Someone please tell me there is someone else that I can do ... any advice or helpful hints???
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 12-23-2007, 01:04 PM
phil6608's Avatar
phil6608 has much to be proud ofphil6608 has much to be proud ofphil6608 has much to be proud ofphil6608 has much to be proud ofphil6608 has much to be proud ofphil6608 has much to be proud ofphil6608 has much to be proud ofphil6608 has much to be proud of
If you have a computer guy that's your friend(someone that works on Fords and programing them)he can disable the PATS system.
Otherwise it has to go to Ford!
__________________
Phil
DE Chapter Board Member/New Castle County
2003 SuperCrew
DSS Built Lightning block/Stage 3 heads and cams
L-conversion/Kenne Bell upgrade blower at 18 PSI
BTS/4R100 tranny
100 shot nitrous
1.68 60' time/11.76 @ 116.17
TRUE GRIT!
2000 Grand Marquis
JOIN THE DELAWARE CHAPTER, CLICK HERE
  #3 (permalink)
Old 12-23-2007, 05:41 PM
ncranchero's Avatar
ncranchero is gaining momentum as a positive member of FTE.
What's the story with that? I have an '05 I'm rebuilding and it would crank with a boost when I got it. I tried bringing the battery back to full charge but it never got there. The other day it cranked and sounded like it was skipping then the next time it wouldn't crank at all, hasn't since. It will hit when you first turn the key but then just spins over. I put a new battery in it, still no start. It has only one key also. Does this sound anti-theft related? I'm beginning to think so. It's at the paint shop but I should be getting it back tomorrow. I don't know if it's fuel problem or electrical/anti-theft. I have a Can/OBD II scanner but putting in the new battery cleared all the codes, if there were any. HELP?? BTW, the "theft" lamp flashes when switched on but then goes out.
__________________
"Information is valued and appreciated
Attitude is not!"
Steve,
'98 F150 Super Cab 4x4
'99 Mustang 35th
'08 E250 Super Duty
No more Ranchero
  #4 (permalink)
Old 12-24-2007, 06:38 AM
phil6608's Avatar
Quote:
Rebuilding? You mean its been in an accident?
When I had problems with the anti-theft system. The truck would turn over great but it would not start at all.It didn't even sound like it sputtered or anything just turned over and over and over.
Your problem doesnt sound like it's a PATS problem.
If it was wreaked. I think there is a fuel cutoff that might have to be reset.
Sorry,,,I don't know ware it is.
__________________
Phil
2003 SuperCrew
BTS/4R100 tranny
100 shot nitrous
TRUE GRIT!
2000 Grand Marquis
  #5 (permalink)
Old 12-24-2007, 08:15 AM
ncranchero's Avatar
Yeah, it got rear ended ......... but it's much better now.
I've reset the inertia switch. The fuel tank was taken out and put back, maybe a line pinched or something. Guess I'll have fun trying to figure this one out. The other symptoms above sounded kinda like mine but my theft light goes out. Oh well.... thanks!
__________________
Attitude is not!"
Steve,
'99 Mustang 35th
'08 E250 Super Duty
No more Ranchero
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
