Shift improver kits ?
Old 12-22-2007, 06:34 PM
okgearhead's Avatar
okgearhead
okgearhead is offline
Hey guys, getting ready to service my transmission, and looking for a shift improver kit for a 4r70w. Any suggestions? Thanks! Tim.
Old 12-23-2007, 10:24 AM
KingRanchMan02's Avatar
KingRanchMan02
KingRanchMan02 is offline
Get a programmer like the Diablosport Predator. It lets you change shift points, adjust line pressures and modulation to improve transmission performance and life. The plus side of a programmer is that you can improve the engine performance and can read and reset DTCs and monitor engine parameters for troubleshooting purposes! Good luck!
Old 12-23-2007, 10:36 AM
fireman28's Avatar
fireman28
fireman28 is offline
I used a valve body from LFP on my old truck. I would advise using a deep pan with drain prug on it if your truck didn't come with one. I used a programmer and then changed to the valve body and liked the shifting much better with the VB. If you run the tranny tunes with the VB you will be laying rubber into second gear everyplace you go. Try this link.
http://www.lightningforceperformance...-c-232_99.html
Old 12-23-2007, 10:50 AM
97Handshaker's Avatar
97Handshaker
97Handshaker is offline
you can get a factory tech shift kit for it. i think they are around 100 bucks
Old 12-23-2007, 11:58 PM
okgearhead's Avatar
okgearhead
Thanks guys !!!
Old 01-05-2008, 09:47 PM
Trevor1's Avatar
Trevor1
Trevor1 is offline
dont go with the programmer, you increase the risk of blowing out or breaking snap rings in the transmission due to increased line pressure
timothy47129
07-19-2006 11:19 AM
SoCalSuperDuty03
Computer Chips & Tuners
03-23-2005 04:22 PM
timjk69
07-06-2003 01:05 PM
tmajikman
01-27-2002 11:54 PM
Quick Reply: Shift improver kits ?
