Shift improver kits ? - Ford Truck Enthusiasts Forums
Old 12-22-2007, 06:34 PM
okgearhead's Avatar
okgearhead okgearhead is offline
okgearhead is starting off with a positive reputation.
Hey guys, getting ready to service my transmission, and looking for a shift improver kit for a 4r70w. Any suggestions? Thanks! Tim.
Old 12-23-2007, 10:24 AM
KingRanchMan02's Avatar
KingRanchMan02 KingRanchMan02 is offline
KingRanchMan02 is gaining momentum as a positive member of FTE.KingRanchMan02 is gaining momentum as a positive member of FTE.
Get a programmer like the Diablosport Predator. It lets you change shift points, adjust line pressures and modulation to improve transmission performance and life. The plus side of a programmer is that you can improve the engine performance and can read and reset DTCs and monitor engine parameters for troubleshooting purposes! Good luck!
Old 12-23-2007, 10:36 AM
fireman28's Avatar
fireman28 fireman28 is offline
fireman28 is starting off with a positive reputation.
I used a valve body from LFP on my old truck. I would advise using a deep pan with drain prug on it if your truck didn't come with one. I used a programmer and then changed to the valve body and liked the shifting much better with the VB. If you run the tranny tunes with the VB you will be laying rubber into second gear everyplace you go. Try this link.
http://www.lightningforceperformance...-c-232_99.html
Old 12-23-2007, 10:50 AM
97Handshaker's Avatar
97Handshaker 97Handshaker is offline
97Handshaker is starting off with a positive reputation.
you can get a factory tech shift kit for it. i think they are around 100 bucks
Old 12-23-2007, 11:58 PM
okgearhead's Avatar
Thanks guys !!!
Old 01-05-2008, 09:47 PM
Trevor1's Avatar
Trevor1 Trevor1 is offline
Trevor1 is starting off with a positive reputation.
dont go with the programmer, you increase the risk of blowing out or breaking snap rings in the transmission due to increased line pressure
C6 type R servo or shift kit timothy47129 Clutch, Transmission, Differential, Axle & Transfer Case 3 07-19-2006 11:19 AM
B&M shift improver with shift kit? DictatorDanny 1987 - 1996 F150 & Larger F-Series Trucks 0 08-11-2005 03:01 PM
SCT Excalibrator and EDGE Juice/Attitude SoCalSuperDuty03 Computer Chips & Tuners 3 03-23-2005 04:22 PM
C-6 shift kit timjk69 Clutch, Transmission, Differential, Axle & Transfer Case 1 07-06-2003 01:05 PM
Best shift kit tmajikman 1987 - 1996 F150 & Larger F-Series Trucks 7 01-27-2002 11:54 PM
Tags
improver, inprover, powerstroke, shift, transmission, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
