Engine Error Code P0420?
If you are not concerned that the cat is not doing what it is designed to do, install a MIL eliminater in the oxy. sensor wire harness.Just a jumper harness plugged in between plug to oxy. sensor(fools PCM).The only way I have cured this code and it stayed away was to replace the cat OR if Ford has an update for this code-reprogram PCM to latest calibration.96 was the first year for OBDII and don't recall ever having a TSB For updateing PCM to cure a P0420.(did alot of Crown Vics though) Google MIL eliminater for more info! lol Blue
