Shift lever adjustment? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 12-22-2007, 05:37 AM
wolfbike1500 wolfbike1500 is offline
wolfbike1500 is starting off with a positive reputation.
My 99 F-350 has recently begun to get a little sloppy in the shift lever department. Sometimes when I put it in park, it does'nt quite seem to get there. It will roll forward or backward depending on the grade and it will make a click sound and almost stop at each click. It's like a pin isn't fully set. It is also a bit sloppy in the other gears. Has been for a while, but the Park thing is what caught my attention. It seems there should be an adjustment on the cable somewhere, but I didn't see anything obvious. Any thoughts?
99 F-350 Lariat V10 4x4 CC LB SRW
Old 12-22-2007, 11:59 AM
redford's Avatar
redford redford is offline
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
The clicking is probably your parking pawl inside of your transmission. It may be worn or cracked. No adjustment is going to fix that.
Old 12-22-2007, 01:32 PM
KSTTAC KSTTAC is offline
KSTTAC is starting off with a positive reputation.
my shifter feels loose, but it shifts into drive, park, reverese with no issues. can you just tighten the shift lever.
Old 12-22-2007, 02:46 PM
locknload223's Avatar
locknload223 locknload223 is offline
locknload223 has much to be proud oflocknload223 has much to be proud oflocknload223 has much to be proud oflocknload223 has much to be proud oflocknload223 has much to be proud oflocknload223 has much to be proud oflocknload223 has much to be proud oflocknload223 has much to be proud of
Could be your shift bushings on your column. My shifter was very loose and sloppy. I checked the teo small torx bolts under the column that normally come loose and they were tight. The column bushings were around six bucks and very easy to swap out. Just remove the clan shell and lower the column buy removing the four bolts that hold it up. I lowered the column so the steering wheel rested on the seat. After I replaced the bushing the slop was about 90% gone so there still may be some wear where the shifter mounts into the column but that's for another day. Feels much better, before it felt like I was going to break the shifter forcing it to move.
The second pic shows the new bushings in place, just have to put the caps over and bolt them down.
Old 12-22-2007, 03:31 PM
Is the bottom picture what it looks like when you drop the steering column?
Old 12-22-2007, 07:53 PM
Yep, here are the caps covering the bushings. I added a little grease in the bushing to smoother action. You'll see that rod (that the bushings surround) have freeplay as you move the shifter. That translates to a sloppy shifter. You can also buy the entire rod from Ford which they suggested but a tech walked in and said they usually just change the bushings.
Old 12-26-2007, 08:31 AM
Just a follow up on what I found...I took the panel off below the steering column and looked around at what was there. I was looking for the two torx bolts locknload refered to. I found them and they were in fact really loose. I could turn them with my fingers. They hold an assembly tp the bottom of the shifter column that connects to the shifter cable and also apparantly to the starter interlock switch. I tightend these up and PRESTO! everything feels much better. I'll still do the bushings, when it gets above freezing outside....
Old 12-26-2007, 08:50 AM
Awesome .
Shift lever problem Keepitrunnin 1999 to 2016 Super Duty 2 02-09-2015 08:02 PM
Sloppy Gear Shift Lever-Automatic Big Sky 1999 to 2016 Super Duty 20 02-05-2013 01:11 PM
damn shift!!! Daviddc114 Excursion - King of SUVs 12 03-20-2011 08:30 PM
1999 f250 4x4 automatic shifter is sloppy fishpimp 1999 to 2016 Super Duty 4 01-01-2010 06:16 PM
Loose shifter on steering column BrokenSockets Aerostar 6 01-24-2005 09:24 AM
Tags
1999, 2000, 350, adjust, adjuster, adjustment, column, duty, f250, f350, f550, ford, lever, shift, shifter, steering, super, superduty
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
