Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Escape and Escape Hybrid
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 12-21-2007, 08:00 PM
ric01 is starting off with a positive reputation.
brakes hiss when driving
Team, another question....
My 2001 Ford Escape V6 hisses every time I release the brake pedal. There’s this hissing sound like leaking air coming from the below the dash near the brake pedal. It actually started a few months ago and comes and goes and was very minor but now it’s louder and happens every time the brake pedal is released. The hissing sounds continues even after my foot is completely off the brake and I’m on the gas pedal. It hisses for a while and when I step on the brakes again it stops but then starts up once I start releasing the brakes again.
Can anyone shed some light on this? Is it a repair I can do myself. The brakes seem fine enough....
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 12-27-2007, 12:53 PM
aquanaut20's Avatar
aquanaut20 is starting off with a positive reputation.
the shaft seal on the brake booster is leaking, change it out before it becomes a problem.
  #3 (permalink)
Old 12-27-2007, 04:58 PM
richert01 is starting off with a positive reputation.
Aquanaut20
I am replacing the grommet on the booster. Had to special order it. When I adjusted the vacuum hose, the hissing became considerably less. I am hoping that will take care of the leak, if not I might have to replace the entire booster. Is the shaft seal something that can be replaced by itself instead of changing the entire booster?
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
