Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Escape & Escape Hybrid
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
  #1 (permalink)
Old 12-21-2007, 06:03 PM
ric01 ric01 is offline
Garage is empty, add now
ric01 is starting off with a positive reputation.
Unhappy rough idle on 2001 ford escape
Hello everyone, hope you can help.
My 2001 Escape has a very rough idle everytime I turn it on. Its worse when I turn it on first thing in the morning. I took it to a Sears auto and they could not figure it out. There is also no check engine light either. I love it but am honestly baffled. We replaced the PCV, changed the spark plug wires and spark plugs. Engine has 111000 miles on it. Has anyone ever experienced anything like this? I have been told by some folks that they do not think its O2 sensors but I dont know.
Please let me know what you think.
  #2 (permalink)
Old 12-22-2007, 01:50 PM
Nitramjr's Avatar
Nitramjr Nitramjr is offline
1997 Ford F-250
Nitramjr has much to be proud ofNitramjr has much to be proud ofNitramjr has much to be proud ofNitramjr has much to be proud ofNitramjr has much to be proud ofNitramjr has much to be proud ofNitramjr has much to be proud ofNitramjr has much to be proud ofNitramjr has much to be proud ofNitramjr has much to be proud of
Welcome to FTE.
If I had to guess, I would say that your brake hiss and your rough idle may be related. Your power brake booster may be shot which is causing a vacuum leak and the vacuum leak may be causing the rough idle.
Without driving the car, disconnect the vacuum line to the brake booster and plug it. Then see if the hissing sound and rough idle go away.
You may also want to put a vacuum gauge on the engine to see if there is a difference with the brake booster hooked up versus disconnected.
__________________
Ray
Avatar is a Pearl Ribbon in honor of my wife and the battle she is waging.
'03 F150 Sport 4x4 4.6L 5-speed, '05 Escape Hybrid, '06 Escape Hybrid
  #3 (permalink)
Old 12-22-2007, 05:40 PM
richert01 richert01 is offline
richert01 is starting off with a positive reputation.
Quote:
Originally Posted by Nitramjr
Welcome to FTE.
Thanks for the welcome. I changed the idle air control valve early this morning (before I read your reply) and it seems to have fixed the rough idle. The ride is much better however, he true test for the IAC valve will be tomorrow morning once the car has cooled over night.
I am interested in trying your vacuum hose suggestion. Is this something that I can try on my own or is some knowhow involved.
Thanks again....
I will keep you posted.
  #4 (permalink)
Old 12-22-2007, 08:50 PM
Nitramjr's Avatar
1997 Ford F-250
Quote:
If you can find the master cylinder and then find the brake booster you should be able to find the large vacuum line that goes to it. Unclamp it, pull it off at one end and plug it with something big enough to plug the hose and not get pulled in. You could even use your thumb to plug it and have a helper start the vehicle.
If you can change an IAC yourself, this should be nothing. Just make sure you put it back togther correctly before driving the vehicle.
__________________
Ray
  #5 (permalink)
Old 12-26-2007, 02:36 PM
I checked the vacuum as you advised. It stops hissing when I go ahead and plug the vacuum hose after removing off the brake booster. I will be placing the brake booster on order at Autozone. Once, I go ahead and replace I will get back to you with a staus update. I am fairly confident that this will resolve the issue once and for all. is there anything you can tell me about removing the booster? Anything you might know? Thanks a million!
  #6 (permalink)
Old 12-26-2007, 06:21 PM
Nitramjr's Avatar
1997 Ford F-250
I've never done one in an Escape but I would advise you to make drawings or take pictures of everything before taking it apart. You may even want to get a good manual that will show you how to do it. Start early in the day in case you need to go to the parts house or tool store halfway through.
And if all else fails, once you get it apart, just come on here and yell HELP and we'll do our best to get you through it.
Good luck.
__________________
Ray
  #7 (permalink)
Old 12-27-2007, 09:30 AM
1978Crew 1978Crew is offline
1978Crew is starting off with a positive reputation.
How was the idle when the car was cold? after you changed the IAC. My Gfriend's 2001 is doing the same thing. I tried to clean the IAC but she still has the same problem.
__________________
1978 F250 2WD Crew Cab 351M/ C6 - SOLD
1999 F250 2WD CC LWB 7.3L 4R100: Door Ajar light Fixed, Power Locks Fixed, Rotella T6 Synthetic, Fuel Bowl Seal Kit
  #8 (permalink)
Old 12-27-2007, 02:19 PM
The idle got a little better after I replaced the IAC but it was still there. I had decided to replace it because it was just really really dirty. There was no cleaning it to an acceptable level.
Tags
2001, 2001ford, breather, cold, control, escape, ford, hissing, hose, idel, idle, idling, problems, replace, rough
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
