my dads 2000 f-250 superduty will not shift out of park, he replaced the brake switch that controls the shifter when you step on the brake but it still won't work. does anyone have any other ideas? thanks in advance
I would check all the fuse's. if they are good will need to find the solenoid on the steering column and test for power and ground with the brakes applied.
