01-03-2008, 08:52 AM
My '87 did the same thing when I used to keep it parked under a maple tree. Those little Maple seeds fell through the vents in the cowling and plugged the drain holes under the wiper mechanism. Moister would find its way into the cab and condensate on the dash and windows. It wasn't to bad until the weather started freezing then I would get the same problem with frost/ice on the inside. I didn’t realize what the problem was until a spring rainstorm drained my battery while I was driving to work with the wipers on; the water level under the cowling had raised so high that it was pouring into the cab and shorting out the wiper motor. I cleaned out the drain vents and never parked under a tree again. I haven’t had any problem with moisture, rain, frost or ice in the cab sense but the damage was already done and my floor board is now all rusted out from the inside.
__________________
John Miller
_________________________
'86 XLT BII Man. Trans & Hubs
'87 Eddie Bower BII Auto Trans & Hubs
