12-21-2007, 08:49 PM
Why do that? I have had experience with engines that have mounts that are too soft, disturbing various components ie, exhaust pipes, shift levers, etc flapping around. I take a length of threaded rod, make 2 brackets, one to bolt to the back of the motor, one to bolt to the firewall, and use shock absorber bushings to absorb motor torquing. Worked like magic. With the proper shock mounting washers etc, it is an hour's work, and much quieter than solid mounts.
