Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 12-20-2007, 08:30 PM
DesertStorm's Avatar
DesertStorm is gaining momentum as a positive member of FTE.DesertStorm is gaining momentum as a positive member of FTE.
motor mounts
Any problem with using solid motor mounts on the 2.3L? I know it will transfer vibration to the frame etc, but will it make any of the sensors on the motor act up like the knock sensor? Or will the vibration hurt the internals of the motor? thanks
__________________
Member of South Carolina Mudboggers Association
94 Ranger 2wd sittin on 33x12.50's.
93 Ranger 4wd sittin on 39's.
Proud owner of 2008 F-150 4X4!!!!!!!!
Lots of scratches and one bent crossmember already with only 1300 on the odo.
p.s. Dont tell anyone but I use it like a truck is supposed to be used.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 12-21-2007, 08:49 PM
TLyttle is starting off with a positive reputation.
Why do that? I have had experience with engines that have mounts that are too soft, disturbing various components ie, exhaust pipes, shift levers, etc flapping around. I take a length of threaded rod, make 2 brackets, one to bolt to the back of the motor, one to bolt to the firewall, and use shock absorber bushings to absorb motor torquing. Worked like magic. With the proper shock mounting washers etc, it is an hour's work, and much quieter than solid mounts.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
