Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V8 (4.6L, 5.4L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 12-20-2007, 02:08 PM
Kymber's Avatar
Kymber is starting off with a positive reputation.
4.6 Swap, maybe?
Ok here's the deal, I have a 2000 F150 4.6 4x4, approx 120k. I have had a knock for almost a year. Took it to a shop and the mech told me not to worry unless it got worse. Well it did. I took it to another mech and he thought it was a lifter issue. I had him tear it down and check it out and he said that he can not find a lifter sticking. The knock seemed to be coming from the 1 and 3 cylinders.
Now he is telling me that he is almost certin that the issue is from a bent connecting rod and that the liner is shot, and I would be better off money wise to swap it out.
He said that he talked to a Ford mech, and was told that the Triton motors had an issue with leaking coolant into the motor which would eventually pool up and cause the rod to bend. Has anyone heard of anything like this?
Also if I do have to swap the motor I would like to swap it with the 5.4. Are the blocks the same block or would I have too many issues to really worry about doing that?
__________________
Chris
00 F150 4.6 4x4 Supercab Styleside
04 Taurus
77 F150 460 C6 NP205 Dana 44 - 456 Ford 9 - 456 40x18 Ground Hawgs- Sold It
97 Explorer V6 4x2-Traded it
89 Bronco 4x4-Sold It
82 F150 302 - Sold It
86 F150 300 I6-Wrecked it
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 12-20-2007, 05:00 PM
countryboy116's Avatar
countryboy116 has a very good reputation on FTE.countryboy116 has a very good reputation on FTE.countryboy116 has a very good reputation on FTE.
go to the 97-03 forums, im also interested in this and theres a guy in that section who has done this, i belive his names fordburntough or sumthing along those lines im sure u could read through some of his posts
  #3 (permalink)
Old 12-21-2007, 12:47 AM
LxMan1's Avatar
LxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to behold
The block is taller and wider than a 4.6L, so you would have to change the exhaust, and such to match up.
I have heard of the 4.2L V6 engines doing this, not the V8's though.
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
  #4 (permalink)
Old 12-21-2007, 06:37 AM
phil6608's Avatar
phil6608 has much to be proud ofphil6608 has much to be proud ofphil6608 has much to be proud ofphil6608 has much to be proud ofphil6608 has much to be proud ofphil6608 has much to be proud ofphil6608 has much to be proud ofphil6608 has much to be proud of
Putting a 5.4 in place of your 4.6 is not a big problem.
Find a 99 to 03 5.4 drop it in.it will bolt right up to your tranny.
You will need to adjust the exhaust and have a custom tune for the computer.
I may be missing a couple miner things.
__________________
Phil
DE Chapter Board Member/New Castle County
2003 SuperCrew
DSS Built Lightning block/Stage 3 heads and cams
L-conversion/Kenne Bell upgrade blower at 18 PSI
BTS/4R100 tranny
100 shot nitrous
1.68 60' time/11.76 @ 116.17
TRUE GRIT!
2000 Grand Marquis
JOIN THE DELAWARE CHAPTER, CLICK HERE
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
