for the sticky: fuel tank capacities - Page 4 - Ford Truck Enthusiasts Forums
  #46
Old 07-28-2013, 11:13 AM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
My '90 has a 19 gal front tank and a smaller rear tank.. maybe 13 gallons. I have replaced it once already and it was always that small, if it was larger I don't think there would be room for a spare tire under the bed.
  #47
Old 07-28-2013, 05:01 PM
kermmydog's Avatar
kermmydog kermmydog is offline
kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.
The PO told me the rear tank was larger & knowing him for years & knowing he can look at almost any classic car & tell you if it is correct or about every option & cost. I knew he must be right, but it made no sense to me. I never had a dual tank truck Ford, Chevy or IHC with a smaller front tank. I never run on the bottom half of the tank so never had a chance to find out. INTERESTING & Thank You.
Craig
  #48
Old 07-28-2013, 06:02 PM
RIKIL's Avatar
RIKIL RIKIL is offline
RIKIL has a great reputation on FTE.RIKIL has a great reputation on FTE.RIKIL has a great reputation on FTE.RIKIL has a great reputation on FTE.RIKIL has a great reputation on FTE.RIKIL has a great reputation on FTE.
My truck originally came with a 15 gallon tank that was above the spare tire. That size tank wasn't going to work for me so I think the first upgrade I did was replace the tank.
This fill-up still took 2 more gallons (45 gal capacity). Each time I go in and give this much cash for the fill-up, they look at my truck and wonder where it goes.
  #49
Old 03-08-2014, 10:35 PM
coasting coasting is offline
coasting is starting off with a positive reputation.
Looking at the fuel lines in your picture, how do you disconnect them? I have a 92 F150 4x4 XL Supercab long box duel tanks, 19 front and maybe a 16 rear, never been able to put more than 15 gals. in it. When I fill the front tank it drips for several hours, I was going to drop it to figure out where the problem is, I have the straps unbolted, sending unit disconnected and filler hose loose, with my floor jack under it holding it up.
I had already changed a valve cover gasket, oil change, air filter, and the starter, and when I saw those connectors decided to call it a day. Ha! Any info would be a help. Thanks.
  #50
Old 03-08-2014, 10:36 PM
  #51
Old 03-09-2014, 10:00 AM
subford's Avatar
subford subford is online now
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
I think there is something wrong with the pump at that station.
37.644 x $3.119 = $117.411636 and not $140.00.
  #52
Old 03-09-2014, 12:35 PM
RIKIL's Avatar
use $3.719
  #53
Old 04-11-2014, 10:42 AM
Mattsoofast Mattsoofast is offline
Mattsoofast is starting off with a positive reputation.
ok I messed up a little bit. I need both tanks on my truck because they are rusted out. Well I ordered the wrong front tank, I need the 19 gal and I ordered the 16 gal by accident and I have started painting them (to try and help them last longer) before I realized it was to small. Will it fit?
  #54
Old 04-11-2014, 09:24 PM
pux17's Avatar
pux17 pux17 is offline
pux17 is starting off with a positive reputation.
Hope this works!
This page shows the capacities for the year 1996 and is from the handout brochure
http://i1067.photobucket.com/albums/...pscbc2b909.jpg
  #55
Old 06-01-2014, 10:26 PM
Streetgliderr Streetgliderr is offline
Streetgliderr is starting off with a positive reputation.
1997 old body style crew cab short box
I can only put 13.5 gallons in mine. 1997 Ford F250 old body style crew cab.?
  #56
Old 06-28-2015, 06:16 PM
PhoebeAnn PhoebeAnn is offline
PhoebeAnn is starting off with a positive reputation.
Data for '91 4x4 (LWB) F-150 Regular Cab tanks
My 1991 Owner Guide says my 4x4 (LWB) F-150 Regular Cab has a standard 18.2 gallon rear tank, and an optional 19.0 front tank. The 19.0 side tank figure shows a footnote (5). The F-250 4x4 has the same front tank, same footnote, and the F-250 4x2 has the same front tank with a (4) footnote.
After all the tank data, the footnote explanations stop at (3). I suspect the missing footnotes (4&5) address the transfer case part numbers; whatever mine is, the 19 gallon tank doesn't fit.
JCWhitney and other vendors say their replacement for the rear tank (OEM part number F3TZ-9002A) is a 19 gallon tank. They offer 17 gallon (OEM F6TZ-9002M) and 19 gallon (F6TZ-9002N) front (side) tanks.
I have a new Spectra F1G (19 Gallon) for the rear, and a Spectra F-14C (JCW: 17 gallon; Amazon & Advance: 16 gallon) for the side. They look like they'll fit; I'll let you know.
**** bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-05-2016 04:27 PM
ooops Aerostar 5 01-14-2015 04:16 AM
... miko6810 Modular V10 (6.8l) 9 06-04-2014 07:14 AM
Albums 56panelford 1948 - 1956 F1, F100 & Larger F-Series Trucks 18 05-30-2014 12:16 AM
Tags
19, 1987, 1996, 2009, 4x4, 94, capacity, f150, ford, fuel, gallon, shortbed, size, tank, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
