for the sticky: fuel tank capacities - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 10-04-2009, 09:07 AM
Volvo92906's Avatar
Volvo92906 Volvo92906 is offline
Volvo92906 is gaining momentum as a positive member of FTE.Volvo92906 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by phoneman91 View Post
I have never seen that configuration neither. The gas door is in front of the rear axle-but none behind the rear axle?? Could we see a side left picture of your truck??
<img src=http://c4.ac-images.myspacecdn.com/images02/52/l_16ff882a42e8457287551336c103a48b.jpg>
  #32
Old 10-04-2009, 11:16 AM
phoneman91's Avatar
phoneman91 phoneman91 is offline
phoneman91 has a good reputation on FTE.phoneman91 has a good reputation on FTE.
Quote:
Never saw one of those before!!! Wonder why ol Henry did that?? Must have a lot of space above the spare tire!!!
  #33
Old 11-23-2010, 05:04 PM
GreenGray's Avatar
GreenGray GreenGray is offline
GreenGray is starting off with a positive reputation.
1996 long bed, 20 gallon front tank (tie down cable hook tore through the original had to replace) 14 rear.
  #34
Old 11-23-2010, 07:12 PM
andym's Avatar
andym andym is offline
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
That's a first for me as well.
4x4 shortbeds with dual tanks do exist. I saw one parked in a parking lot once.
  #35
Old 11-23-2010, 07:30 PM
Encho's Avatar
Encho Encho is offline
The Southernmost Mod
Encho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant future
89 - 96 Broncos: 33 gals.
  #36
Old 11-23-2010, 07:48 PM
So-Cal Sancho So-Cal Sancho is offline
So-Cal Sancho is new and has a neutral reputation at this point.
1996 f250, 4x4 shortbed. front and rear tanks. I think supposed to be 16 front and 18 rear, but when the needle reads empty i can only get 12 in either. must have crap in there.
  #37
Old 07-30-2011, 10:00 PM
F250HD Custom F250HD Custom is offline
F250HD Custom is starting off with a positive reputation.
Strangely enough, guys, my 1987 Ford Truck Factory Owners "Do It Yourself" Guide Lists ONLY 19 gallon tanks, front and rear, for everything except SWB (standard wheel base - non supercab/crewcab) two tank trucks, which have a 16.5 front. So did the latter models get shafted with smaller tanks?? F250HD Custom
  #38
Old 10-25-2011, 08:08 AM
kidkyle21 kidkyle21 is offline
kidkyle21 is starting off with a positive reputation.
no extra large tank for the 1991 super cab longbed
do they make a 33-32 gal. tank for a 91 f-250 super cab 8' bed i have heard that ppl get the bronco tank in there but ford did somthing that yr with the fuel system and nobody make a large rear tank (that i can find) tips advise please my rear tank need to be replaced
  #39
Old 10-26-2011, 09:31 PM
FirecrackerKTM FirecrackerKTM is offline
FirecrackerKTM is starting off with a positive reputation.
95 F150 single cab short bed 4x4, and today with the needle on the E, it only took 12.8 gallons to fill
  #40
Old 04-03-2012, 08:21 PM
fudimanuchi fudimanuchi is offline
fudimanuchi is starting off with a positive reputation.
Check "transfer Flow, Inc" at transferflow.com. They have 40 to 60 gallon tanks.
  #41
Old 04-06-2012, 10:29 AM
GymClassHero GymClassHero is offline
GymClassHero is starting off with a positive reputation.
Quote:
Originally Posted by jarod17 View Post
As soon as I get the cash my '96 long bed will have 50 gallon front and 18 gallon rear.
50 gallon front? What/who makes a 50 gallon front tank?
  #42
Old 04-06-2012, 11:56 AM
Ddaybc's Avatar
Ddaybc Ddaybc is offline
Ddaybc is starting off with a positive reputation.
My Ford Owners Manual lists my tank capacities as 19 front and 18.2 rear, US gallons. My truck is a 94 F150 Extra Cab Long Box. 15.8 and 15.2 Imperial or 72 and 79 liters respectively. At our current price of 129.9 per liter it costs a small mortgage to fill from E. Still love my truck though.
  #43
Old 06-28-2013, 11:27 PM
boonslick boonslick is offline
boonslick is gaining momentum as a positive member of FTE.
Fuel Capacity
My 1987 F150 XLT Lariat single cab holds 19.x, Front and 15.x Rear although I have yet to run them "dry."
Boonslick
  #44
Old 07-27-2013, 10:08 PM
Robuilt's Avatar
Robuilt Robuilt is offline
Robuilt is starting off with a positive reputation.
I had read a few years ago that 32 gal bronco tanks could be mounted in the bed of a truck with the spare tire removed.
I cant seem to find a reliable link now.
any confirmation on this?
  #45
Old 07-28-2013, 10:54 AM
parkerparkerm parkerparkerm is offline
parkerparkerm is starting off with a positive reputation.
So my 94 f350 CCLB 4x4 (351/E4OD) holds 19.5 front and 15.2 rear?
Also, my 85 f250 RCLB 4x4 (300/T18) has a single front tank if it matters, unknown size but its pretty large and even with the tiny 4 speed and married case theres only about 6-8" from the t-case and gas tank touching.
**** bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-05-2016 04:27 PM
ooops Aerostar 5 01-14-2015 04:16 AM
... miko6810 Modular V10 (6.8l) 9 06-04-2014 07:14 AM
Albums 56panelford 1948 - 1956 F1, F100 & Larger F-Series Trucks 18 05-30-2014 12:16 AM
Tags
19, 1987, 1996, 2009, 4x4, 94, capacity, f150, ford, fuel, gallon, shortbed, size, tank, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
