for the sticky: fuel tank capacities - Page 2 - Ford Truck Enthusiasts Forums
Old 08-25-2008, 09:38 PM
kuzycc kuzycc is offline
kuzycc is starting off with a positive reputation.
My 94 half ton (Short bed) and my 94 3/4 ton (Long Bed). Both held the same, When both tanks were on E, you can fit about 34 gallons total among the two tanks.
Old 10-05-2008, 03:01 AM
customfoam customfoam is offline
customfoam is starting off with a positive reputation.
My 93 shortbed 16 front 17 rear.
Old 10-05-2008, 06:46 AM
phoneman91's Avatar
phoneman91 phoneman91 is offline
phoneman91 has a good reputation on FTE.phoneman91 has a good reputation on FTE.
Isnt the size of the front tank dependent on if the truck is a 4x2 or 4x4 and if it is a long bed or short bed??
Isnt the reason that 4x4 short beds are all single tank because the transfercase doesnt allow the front tank?? But the earlier pre1990 or so 4x4 short bed had dual tanks-why?? And the post 1990 4x4 short bed cant??
Old 10-05-2008, 05:58 PM
I dont think so all the ford trucks 92 to 96 I think run two tanks
Old 10-05-2008, 06:41 PM
jroehl jroehl is offline
jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.
Quote:
My '93 owner's manual lists shortbed regular cabs as having a single tank. It's tough to speak authoritatively about the some 5 million trucks that Ford built in those 5 years...
Jason
Old 10-05-2008, 11:59 PM
jonwoos's Avatar
jonwoos jonwoos is offline
jonwoos is starting off with a positive reputation.
Wrong. My <<<< 94 F150 regular cab short bed 4x4 is a single rear tank only truck.
Old 10-06-2008, 05:36 AM
phoneman91's Avatar
Quote:
Nice looking truck! I just love 4x4 shorties! Where is your side molding aft of the rear wheel openings?
But the 87 thru 89 or so 4x4 shortie could be equipped with factory dual tanks! The transfercase changed about 1989 or so and I think that this is the reason for the single 18.2 rear tanks for post '90 short cab/short box 4x4s. Just no room for a side tank and the new transfercase!
Old 10-06-2008, 10:12 AM
jonwoos's Avatar
My body man, and I thought it would look better without it. It has different Reflexxion cowl hood, diseal bumper, and Lightning airdam/foglights. I have a farm truck that is a 88 F150 4x4 RCSB also, you are correct, it has 2 tanks, but only one working at the moment.
Old 02-28-2009, 03:01 AM
460/5's Avatar
460/5 460/5 is offline
Zombie Survivalist
460/5 is a name known to all460/5 is a name known to all460/5 is a name known to all460/5 is a name known to all460/5 is a name known to all460/5 is a name known to all
ROTFLMAO! The ONLY reason i would get a tank that big, is so i only have to fill it once every three months... or maybe if i pulled trailers for a living... I hate small tanks the put on trucks with big engines... I hate gas prices too!!!
Old 05-26-2009, 03:41 PM
RedaxeVT RedaxeVT is offline
RedaxeVT is starting off with a positive reputation.
Does the 19 gallon Side tank fit in a 4wd?
Hello folks. I am a new member to the Forums and this is my first post.
I just ordered a 19 gallon side tank to replace the rusted out tank in my '94 4wd. After removing and researching pics online of what looked like my tank It turns out the hopelessly rusted tank I took out of the truck was NOT a 19 gallon, but a 17 gallon instead. The new 19 gallon tank I ordered was delivered to my door this morning and is aprox. a foot longer than the old tank. I *Think* it will fit with a pair of new straps designed for the 19 gallon tank, BUT I am not sure. BEFORE I go trying to install this shiny new tank, can anybody out there tell me if a 19 Gallon side tank fits in a 94 4wd(full size)? ...or should I just return it and get the smaller one?
any feedback or advice is welcome.
Thanks
Old 10-03-2009, 06:45 PM
TOPS's Avatar
TOPS TOPS is offline
TOPS is starting off with a positive reputation.
Well what is It?
1995 F-150XLT 5.oL dual tanks, with all the differance answers that is posted in this thread have not told me nothing ,does anyone know what my truck had Auto Zone ask me, I may need a fuel pump.
Old 10-03-2009, 08:59 PM
I had a 93 ext cab with two tanks, I have the front side tank if you need it suppose to be a 17 gallon, brand new that I would like to get rid of
  #28
Old 10-03-2009, 10:42 PM
Volvo92906's Avatar
Volvo92906 Volvo92906 is offline
Volvo92906 is gaining momentum as a positive member of FTE.Volvo92906 is gaining momentum as a positive member of FTE.
I have an 88 4X4 long bed with a single front tank. Thats one configuration that I have never seen anywhere else.
  #29
Old 10-03-2009, 11:04 PM
phoneman91's Avatar
Quote:
I have never seen that configuration neither. The gas door is in front of the rear axle-but none behind the rear axle?? Could we see a side left picture of your truck??
  #30
Old 10-04-2009, 07:56 AM
Volvo92906's Avatar
I will post it early this afternoon
**** bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-05-2016 04:27 PM
Delete Glowplugger 1999 - 2003 7.3L Power Stroke Diesel 0 04-20-2015 12:09 PM
fdgdfgdf nmclella Testing..... 0 04-12-2015 06:23 PM
cgh lawdawg79 1999 to 2016 Super Duty 0 04-09-2015 09:04 PM
Tags
19, 1987, 1996, 2009, 4x4, 94, capacity, f150, ford, fuel, gallon, shortbed, size, tank, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
