Rear View Mirror Color
I've seen them three colors; don't know the proper color; but I say its close to the color called Silver smoke gray. I seen white as standard color; chrome, and this Sliver Smoke gray. I would paint it white; if you can't figure out the shade of gray you want' or the best bet is to put in a aftermarket chrome one.
Hope this helps.
Mitch
Hope this helps.
Mitch
Originally Posted by gangstakr
Paint it the same color as your interior metal. keeping it uniform gives it a good look.
Bill T.
Originally Posted by FXDC4419
I thought about doing just that, however I have not yet made up my mind. Should it be White or should be the Sand color? I am open to opinions look at my gallery to see the colors and let me know what you think.
Bill T.
Bill T.
Originally Posted by firstrider
Some what of a related question . What is the correct color of painted parking light frames on a ' 51 or '52 F-1 . Are they argent silver or the creame / ivory color like the grill ? Thanks FTE members
1961/66 inside rear view mirrors: Most of what I've seen were a non reflective gray, but chrome mirrors (C3AZ-17700-A [NOT B]) were used on Custom Cabs, and two adjustable chrome day-night mirrors were an option.
Day/night mirrors: There are two different types...both were used during the same time frame (C3AZ-17700-D **** type / C2AZ-17700-B toggle type). One had a **** that could be swiveled to flip the mirror up/down, the other had a black plastic knurled toggle switch at the bottom of the mirror. Both mirrors are marked on the backside with the FoMoCo script and are the same ones used on most 1960-66 Ford's including 1965/66 Mustangs, so they're not that hard to find.
These are not the same mirrors that glue to the windshield, these mirrors thread on. Glue-ons were first used on 1961/66 T-Birds. Most Fords had black plastic day/night mirrors glued on in 1967.
btw: The "plain jane" chrome inside mirrors used on Custom Cabs are the same as 1960/66: Galaxies, Fairlanes, Falcons; 1965/66 Mustangs.
I purchased a mirror for my 64 that included a map light after modifying original mirror bracket I ran the wire through the bracket and to the switch. I'm no purist I like being a little different. If I can use original brackets and hole areas I will but I just like being different. I have a good picture of the mirror in my gallery. tell me what you think.
And I modified my mount in "Christine" by adding 2 inches to the mount to actually see freeway traffic in back of me. Painted Bright White.
Argent Silver is the closest i have found to the grey ford used on the mirrors.
I have yet to see one of the optional day nights in a stock truck.
Garbz
Garbz
Originally Posted by garbz2
I have yet to see one of the optional day nights in a stock truck.Garbz
I've seen several, both were in Rangers.
