Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Bronco II
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 12-19-2007, 11:31 AM
SShank42's Avatar
SShank42 is starting off with a positive reputation.
Heater hoses
1987 BII with a 2.9. Does it make any difference which way the hoses attach to the heater core? Does the pass. side core hose go to the nipple nearest the thermostat housing or the other way. I'm fighting a not much heat issue. I have the Prestone flush kit installed. So I undid the the hoses from the kit and could easily blow thru (by mouth) all four sides of the hose and watch it blow out the other ends. So I am assuming no blockages. So then I started it up with the hoses unhooked and had good flow from one hose. Normal right? I also replace the thermostat and checked that the heat control valve was working properly. Topped everything off and made sure to get air out. Still only like warm heat. So I is it possible the heater hoses are backwards? Thanks
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 12-19-2007, 12:22 PM
5.0B2 is starting off with a positive reputation.
The heater core isn't directional - sorry. Try pulling the core cover off and checking for something blocking the air flow.
__________________
1965 Falcon Ranchero hiPo 289 9"
1979 Lincoln Versailles 351W 4v
1984 BII 5.0FI 4R70W B/W 1356 d35 & 8.8/disks
1997 Explorer Sport 4.0 OHV
  #3 (permalink)
Old 12-19-2007, 12:37 PM
SShank42's Avatar
That what I thought but wa not sure. Air blows strong out the registers.
  #4 (permalink)
Old 12-19-2007, 02:16 PM
Help I M Stuck is starting off with a positive reputation.
all the heater core is-is like a extended hose with fins..it dont matter which way they go. God knows i've replaced plenty of them and never remember which is when when i put them back on. Never had any problems.
__________________
-Jeff
86 Bronco II 4inch suspesnion lift, 3inch body, 35x12.50x15 BFT AT/s and 4:10gears.
05 F250 Superduty Diesel--tows the BII to the trails
  #5 (permalink)
Old 12-21-2007, 01:02 AM
plilikoi is starting off with a positive reputation.
It sounds as though the heater core is blocked. You can't expect being able to blow through the hoses, especially by mouth, to be a fair test. Air passes through restrictions much easier than water and you can't begin to mimic the volume of fluid that passes through the heater core. I would hook up a garden hose to one side of the heater core and pulse the pressure, turning it on and off in very short bursts. Ideally you'd hook up the water to the outlet side of the heater core lest you make the blockage worse. Fortunately, the heater core is cheap and easy to replace on this vehicle.
__________________
Richard
Original owner of an '88 4x4 "manual everything" Bronco II. Takes a licking and keeps on ticking, 176,000 miles to date.
  #6 (permalink)
Old 12-21-2007, 08:39 AM
SShank42's Avatar
Make about the volume, never really thought about that.Guess it could have a restriction. It would suprise me thought. The whole cooling system is new after the reman engine went in. Actually I have replace the heater core twice since then. They kept splitting down the sides. Not sure what was up with that. Like you said they are cheap and easy. 30 min. or so and it done.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
