Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 12-20-2007, 02:01 PM
OrangeJuice is starting off with a positive reputation.
Hey everyone, Thank You for your input. I really like this site with the intrest and knowledge we all share. My Melling camshaft has a lift of .510 and a 282 duration. If I were to change it out, what kind of lift and duration should I go with to be a strong runner without losing too much low end torque - .530, .550, .570? Comp Cams or Crane Cams or something other? My cobra-jet heads can handle a .600 lift. I can swap out the intake for the RPM and have some head work done. How much horsepower gain can I expect after having these changes made?
Thanks again everyone.
Sponsored Links
To remove this ad, register today!
  #17 (permalink)
Old 12-20-2007, 02:43 PM
baddad457 is starting off with a positive reputation.
Depends on what cam. And you'll also have to possibly go aftermarket with the rocker shafts if you get too radical a cam. With a lift of no more than .530 or so and a max duration of about 290* (advertised) you'll be OK on the stock shafts, possibly more, I couldn't tell you never having gone bigger with an FE.
  #18 (permalink)
Old 12-20-2007, 03:26 PM
pbear6969 is starting off with a positive reputation.
I'm not 100% sure of the HP/TQ gains, but it would be noticeable... We ported and polished my dad's heads and then he had the CJ valve's installed and got a RPM intake. He used the Comp 33-230-4 cam which has 280 duration and a .530 lift. It hits good and has good power throughout the power range. http://store.summitracing.com/partde...4&autoview=sku That's a link to the cam on Summit. He went from the performer intake just like you have to the Comp-RPM set up. He just drives the truck once in a while so he didn't want anything to wild. I have drove his and compared it to mine. His don't have the TQ mine does, but still runs VERY well. Hope this helps.....
He still has the stock rockers and shafts installed so that shouldn't be a problem.
__________________
JOSH
1968 F100-modded 390-C6 w/3.70 posi gear
ANYONE BUT OBAMA 08'!!!
  #19 (permalink)
Old 12-20-2007, 06:37 PM
What truck is all this in anyway? Transmission? Rear? Tires? Reason I ask is if this is something like an F250, you'd really be wasting money swapping in a hotter cam. F100? That would be a different story.
  #20 (permalink)
Old 12-20-2007, 07:09 PM
Ford428CJ's Avatar
Ford428CJ is starting off with a positive reputation.
Give Ken @ Oregon Cam Grinders a call! He will make you a killer cam for your application and more reasonable then Comp or Crane cams. Here is a link:
http://home.pacifier.com/~orcam/regrinding.html
There are a # of guys that run his stuff and are very happy!!! JMHO
__________________
Wes Adams FORD428CJ
Built Ford Tuff With Good Ford Stuff
79 F-250 X-Cab 4x4 6.9 Turbo Diesel
64 Falcon X-Ram 428
55 FORD Truck 4-link Rides on air with X-Ram 428
67 Stang 351 C/J
2000 Yamaha V-MAX VMOA#4277
  #21 (permalink)
Old 12-20-2007, 08:09 PM
RapidRuss's Avatar
RapidRuss is gaining momentum as a positive member of FTE.
I wouldnt pay much attention to the above Wes's comment.....RandyB that use to run around here and post during his build..Put his 395" er in a 96 F250 junkyard 4X4 and with a Carne RPM cam could still turn over either 38" or 40" tires...
I wonder if he still has his Gallery up? he was running stock edheads , the RPM intake,and the RPM Cam, It was a build that HotRod Rag. Did....and it made 420hp @ the FW... with nothing real special other than bolt ons.....
But Wes is right..I have heard nothing but good things about Oregon Cams..also..I dont have any experience with them..But do know some guys that run the 385 series motors that run there cams and have been quite happy..
RJ
__________________
Blue Saphire 70 F250 390/C6 Limited Slip 4.10
Hedman Full length
Holley 750
B&M Mega shifter
Sunpro 5" Super Tach III
ION 138 series wheels
With a Secret BBF/TBA sometime??
  #22 (permalink)
Old 12-20-2007, 09:08 PM
dbossman is starting off with a positive reputation.
bad rap
Not sure why that cam gets such a bad rap. Its very very similar to a factory 390GT/428CJ cam. In fact, its perhaps a little bit bigger.
Barry Robotnik sells them at Survival Motorsports.
I'd give Barry a call and see what he recommends. He is one of the best FE guys around.
Tim
  #23 (permalink)
Old 12-20-2007, 10:00 PM
Ford428CJ's Avatar
RJ
OUCH Russ!!! LOL That hurt man LOL......
We used it in the blown 440 Charger, a solid flat tappet cam From Ken. He custom ground the cam for our application and what we wanted. I cant say enough about Ken. There are quite a few on the Ford FE Forum as well. Your choice and no pressure. Just trying to help out is all and just another avenue to pursue. JMO
Here is a video of when we First got it Running. And we did a lot more tuning and tweaking since then! Enjoy. By the way that is me driving and my son when he was 3 years old LOL
http://www.youtube.com/watch?v=tvUB8mgpNlA
__________________
Wes Adams FORD428CJ
64 Falcon X-Ram 428
67 Stang 351 C/J
  #24 (permalink)
Old 12-20-2007, 10:29 PM
RapidRuss's Avatar
Oh no no no Wes... I was hoping you wouldnt take it like that Bro....I thought I had said the Post just above yours ...lol... I know you know your *****..I would never pick on you intentionally....LOL.. I may poke fun at you from time to time...But you remind of remind me of me when I was your age....But at that time I was building the brand X motors.... That was ment for the post above your....From some quack!!! lol..
Sorry little Bro..it wasnt meant for you...
RJ
__________________
Hedman Full length
Holley 750
B&M Mega shifter
  #25 (permalink)
Old 12-20-2007, 10:33 PM
RapidRuss's Avatar
See Wes....i did say above Wes's comment...as in the one above yours ?? LOL
RJ
__________________
Hedman Full length
Holley 750
B&M Mega shifter
  #26 (permalink)
Old 12-21-2007, 12:04 AM
Ford428CJ's Avatar
RJ
LOL Got ya Russ LOL.
I think a better cam and intake would help out a lot if you ask me! I know some people would say the cam in my 428 that was in my Blue Beast is a little to hot but really not! Dration @ .050 is 228 & 234 on a 110
__________________
Wes Adams FORD428CJ
64 Falcon X-Ram 428
67 Stang 351 C/J
  #27 (permalink)
Old 12-21-2007, 12:22 AM
RapidRuss's Avatar
LOL Wes, No worries here......I just wish the hell you would have told me you were going to get rid of it.....that would have givin me an excuse to run out west for a few weeks....lol...and Pus been able to attend your annual BBQ...
I still cant wait til you put that roller bump stick i sold you into something so I can hear it..... BTW..I ran across 2 Cam pins I need to send you....
RJ
__________________
Hedman Full length
Holley 750
B&M Mega shifter
  #28 (permalink)
Old 12-21-2007, 12:26 AM
Ford428CJ's Avatar
RJ
COOOOOL Russ! I'll send ya my addy by email off the Ford FE forum tomorrow....
__________________
Wes Adams FORD428CJ
64 Falcon X-Ram 428
67 Stang 351 C/J
  #29 (permalink)
Old 12-21-2007, 07:52 AM
RapidRuss's Avatar
Ok Bud, Sounds good to me.....
__________________
Hedman Full length
Holley 750
B&M Mega shifter
  #30 (permalink)
Old 04-15-2008, 03:32 AM
63monty is starting off with a positive reputation.
Way off. Try a low end of 300 hp with the lower comp pistons and 330 hp with the 10.5. This is probably still low since the quotes were only between 3000-3500 rpm depending on model. As for torque try a rating of 425 at 2500 rpm on the 10.5 models. Those quotes are at the flywheel of course.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
