Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 12-19-2007, 10:52 AM
V10raisinCane V10raisinCane is offline
V10raisinCane is starting off with a positive reputation.
Help With Headlights!!!
I need help. I have an 03 Ex, and my headlights wont shut off. The only way to get them both off is if I unhook the battery. I pulled every fuse out of the block, and nothing, I could only get the passenger side to shut off. I figured it is either a relay, or the switch, but a friend of mine told me its the fuse block. He said it is very common with excursions and that the part is 300 bucks!!! Anyone had this problem? Any suggestions?
  #2 (permalink)
Old 12-19-2007, 11:11 AM
ukmat71's Avatar
ukmat71 ukmat71 is offline
ukmat71 is starting off with a positive reputation.
do you have daytime running lights, my ex is from canada and they are always on.
would be nice to turn them off.
or do you mean when the keys are out the lights stay on ?
__________________
00 Excursion XLT 4x4 6.8 V10 for family
95 Mitsubishi Lancer Evolution 4x4 GSR for fun
  #3 (permalink)
Old 12-19-2007, 11:36 AM
I turn the truck off, make sure the light switch is turned to off, (it also has the auto. light which I dont have turned on). I can still turn on/off the foglights, but the headlights simply wont shut off. I take out the keys, and I could come back in 2 hours and they are still on. A friend also told me about a centenial switch that some have where you can adjust how long your lights stay on after you shut off your truck. He said that could be broke, I looked for it, couldn't find anything like that, so I dont know if that is the problem. I simply pulled the bulbs out so my wife could still drive during the day. I dont have 500 bucks for this shop to try to fix it with X-mas here, so I have it rigged up for now. We have been driving my truck at night. I cant figure this thing out.
  #4 (permalink)
Old 12-19-2007, 12:19 PM
MarkMoore's Avatar
MarkMoore MarkMoore is offline
MarkMoore has a good reputation on FTE. MarkMoore has a good reputation on FTE. MarkMoore has a good reputation on FTE.
This is for my 2001, but it may be the same. You could give it a try and see if maybe the AutoLamp feture is hosed...
Quote:
Autolamp control (if equipped)
The autolamp system provides light
sensitive automatic on-off control of
the exterior lights normally
controlled by the headlamp control.
The autolamp system also keeps the
lights on for approximately 20
seconds after the ignition switch is
turned to OFF.
To program the autolamp feature, do the following:
1. Start with the ignition in OFF and the autolamps selected.
2. Deselect the autolamps.
3. Put the ignition in RUN.
4. Put the ignition in OFF.
5. Select the autolamps. Steps 2 through 5 must be performed within a
10 second period. At this point, the headlamps and parking lamps will
turn on.
6. Deselect the autolamps after the desired autolamp delay time
(maximum of 3 minutes). At this point, the headlamps and parking
lamps will turn off.
Foglamps are not controlled by the autolamps. In order to turn on the
foglamps, you must turn the lamp switch to the position and pull
toward you for fog.
__________________
- The Urban Assault Vehicle -
2001 Excursion Limited, 4x4, V10, 3.73
RoadMaster Active Suspension
2001 Prowler 31G
Equal-i-zer WD Hitch
Prodigy Brake Controller
http://www.ford-trucks.com/user_gall...id=194723&.jpg
  #5 (permalink)
Old 12-19-2007, 12:34 PM
rokhedjo rokhedjo is offline
rokhedjo is starting off with a positive reputation.
check to see if your headlight switch is bad, that is what it sounds like.
__________________
2000 Excursion 4x4 v-10 3 inch lift,Bilstein shocks,F-250 chrome grill,Helwig rear sway bar,Gibson exhaust,K&N filter, and now ICC lights.
  #6 (permalink)
Old 12-19-2007, 01:31 PM
SFeintuch's Avatar
SFeintuch SFeintuch is offline
SFeintuch is starting off with a positive reputation.
sounds like something got hot and melted inside your headlight switch. unplug it and see if the lights go off.
__________________
05 Excursion LTD. 6.0 4x4
  #7 (permalink)
Old 12-19-2007, 01:42 PM
njstevens's Avatar
njstevens njstevens is offline
njstevens is starting off with a positive reputation.
The headlight swict (older) sucked. That would be my first place to look. Pull that swicth and like SFEIN said unplug it and see if they go off. I dont remember how much a new switch was but it wasnt $500.
__________________
2000 X Diesel, 6in Pro Comp system, new TrXus SS 35's, 16x10 Rockcrawler Series rims, Superchip
My Beast is back on the road with new headlights, hood, bumper and grill.
  #8 (permalink)
Old 12-19-2007, 10:42 PM
Thanks a lot for the help. I have to work late tomorrow with Christmas coming up, so I wont get a chance to mess with it until Friday night. But I was thinking it was either the switch or a relay, I just haven't had the time to mess with it, I'm really hoping thats what it is.
  #9 (permalink)
Old 12-22-2007, 12:12 PM
I unplugged the switch, and still nothing, the lights still stay on. Like I said, the only way I can get these off so far is by pulling the battery or pulling the bulbs. I've pulled every single fuse in this truck, tried reseting the computers, everything. I am about to try the last idea of trying to reset the Autolamp control. I dont know if my truck has it or not, but I guess I'll find out. Its an 03' Limited 4-wheel drive. ANY HELP would be awesome, I'm stunned.
  #10 (permalink)
Old 12-22-2007, 07:35 PM
gotta be a stuck relay between the switch and headlights, let me look at the schematic in my repair manual.
__________________
  #11 (permalink)
Old 12-22-2007, 07:43 PM
In the auxiliary relay box #2 , there is a relay "daytime running lamps relay 2" unplug it and see what happens.
__________________
  #12 (permalink)
Old 12-22-2007, 10:24 PM
Where is the auxilary relay box #2 located?
  #13 (permalink)
Old 12-22-2007, 11:10 PM
engine compartment
__________________
  #14 (permalink)
Old 12-23-2007, 09:23 PM
I looked in the engine comp. and I couldn't find it, driver or passenger side?
  #15 (permalink)
Old 12-25-2007, 03:42 PM
that is where my manual says it is, i will look on mine and try to find it.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
