Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #16 (permalink)
Old 12-25-2007, 08:23 PM
rokhedjo rokhedjo is offline
rokhedjo is starting off with a positive reputation.
look next to the master cylinder
__________________
2000 Excursion 4x4 v-10 3 inch lift,Bilstein shocks,F-250 chrome grill,Helwig rear sway bar,Gibson exhaust,K&N filter, and now ICC lights.
  #17 (permalink)
Old 12-25-2007, 09:24 PM
kev03 kev03 is online now
kev03 is starting off with a positive reputation.
fuses for this is #7,30,46,47, These are the only fuses for the lights and there is not a fuse box under the hood on the 03 . But there is a couple of relays on the iner fender well on drivers side which i am not sure what they are for. but I do know a bad ground can affect how the lights work. I have an 03 4x4 7.3 l excursion.
  #18 (permalink)
Old 12-26-2007, 11:37 AM
my manual only goes up to 2002 model in the wiring diagrams, although the cover says 1999 - 2006 ? I can only say that a relay now is the most likely culprit in your situation, I am an Aircraft mech/electrician, and relays on aircraft fail quite often. they will fail open most of the time, but they will fail in the closed position also.I would try to locate the headlight relays, there are 2 relays on the 2002 models with daytime running lights. try hooking up your battery and pulling the relays you found and see if the headlights turn off when you pull one of them, if not , try to find the right relays, I dont know what else to tell you other than to trace the power back with a meter till you find something [common troubleshooting techniques] . grounds can be a problem, there are ways to see if a bad ground exists with a meter, probe from the component ground point to a known good ground and see if there is voltage present, there should be very litle if any, if you see a significant amount of dc voltage there is a bad ground.I hope this will be of some help yo you since my typing really is s-l-o-w, and this took me about 15 minutes to type...lol.
__________________
  #19 (permalink)
Old 12-26-2007, 05:29 PM
mohrds mohrds is offline
mohrds is starting off with a positive reputation.
Quote:
Originally Posted by rokhedjo
...and relays on aircraft fail quite often. they will fail open most of the time, but they will fail in the closed position also.....
Am I the only one who gets a little queasy when I read "aircraft" and "fail" in the same sentence??
  #20 (permalink)
Old 12-26-2007, 06:11 PM
  #21 (permalink)
Old 12-26-2007, 07:46 PM
71-4R3SONS's Avatar
71-4R3SONS 71-4R3SONS is offline
71-4R3SONS is gaining momentum as a positive member of FTE.
Quote:
Me too!!!
__________________
BOB Spelled backwards is BOB.
2005 EXCURSION--Eddie Bauer--4x4--V-10
Dale Jarrett FORD / NASCAR Special Edition
  #22 (permalink)
Old 12-26-2007, 08:48 PM
When you are building new planes, you find the bad parts pretty quick. Parts fail ,thats why there are backups.Military aircraft have even more backups tham most commercial, lots of redundancy.
__________________
  #23 (permalink)
Old 12-26-2007, 08:50 PM
were you studdering?.........or just repeating yourself ? ? ? ? ? ?
__________________
  #24 (permalink)
Old 12-26-2007, 09:32 PM
njstevens's Avatar
njstevens njstevens is offline
njstevens is starting off with a positive reputation.
I believe it is drivers side. Sounds to me like you have a gremlin in that their truck. Let us know what it is because that is really spooky if it is not the relay
__________________
2000 X Diesel, 6in Pro Comp system, new TrXus SS 35's, 16x10 Rockcrawler Series rims, Superchip
My Beast is back on the road with new headlights, hood, bumper and grill.
  #25 (permalink)
Old 12-27-2007, 09:09 AM
V10raisinCane V10raisinCane is offline
V10raisinCane is starting off with a positive reputation.
I am going to check it out this weekend, I've just been too busy at work and with the holidays, its hard to grab an extra hour to actually try to figure it out, as soon as I know, I'll let everyone know. Thanks so much for everyones help.
  #26 (permalink)
Old 12-27-2007, 03:15 PM
Sometimes my browser freezes during a post. If I hit stop and refresh it either doesn't post or posts it twice. I was looking on the edit window for "Delete Post" but I couldn't find one.
  #27 (permalink)
Old 03-03-2008, 09:07 PM
RagdollRacer RagdollRacer is offline
RagdollRacer is starting off with a positive reputation.
Did anybody solve this issue. I am having the same problem and I have no electrical diagrams. I have pulled the switch and it does not turn off the lights. I have pulled the three relays in one of the boxes under the hood and no joy. Are there any lighting relays under the dash in the hugh fuse/relay box?
  #28 (permalink)
Old 03-04-2008, 09:29 PM
I REALLY need to know how you solved this problem. I have the same thing in my 03 and have run out of ideas.
Please, Please help.
  #29 (permalink)
Old 07-03-2009, 05:32 PM
BIGGJOE BIGGJOE is offline
BIGGJOE is starting off with a positive reputation.
2002 FORD EXCURSION ELECTRICAL PROBLEM:
While driving the vehicle the smell of wires burning was noticed with a small plume of smoke viewed coming up from the upper LEFT side of the steering column shroud (not the steering wheel).
The battery was immediately disconnected. Upon inspection NO fuses were blown. All fuses checked out good. NO wires were found burned, damaged, or frayed. ALL electrical components appear operative with the following exception.
During TEST: In PARK, w/ignition key on, while checking light functions, the back-up sensor alarm went on (beeping) momentarily (twice). After several repeated attempts the incident did NOT re-occur.
Can anyone HELP? Got any ideas?
Please advise smoothbella@netzero.com
Thank you.
  #30 (permalink)
Old 07-03-2009, 11:21 PM
wallz's Avatar
wallz wallz is offline
2002 Ford Excursion
wallz has a good reputation on FTE. wallz has a good reputation on FTE.
BIGGJOE welcome to FTE! check out this link to see if this is you problem.
http://www.ford-trucks.com/forums/74...uestion-3.html
__________________
2002 Excursion, 4x4, V-10, some mods, and many more to dream about!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
