You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Uh...it would be helpful to know what you're working on. What year, carbed or EFI? What engine? With a little more info we can steer you in the right direction.
__________________
"alot" is not a word...
Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
This can be a little tough...with EFI there are lots of integrated systems, it's not as simple as hooking a up a single hot wire to the ignition on an old-style points-ignition engine. I'll have to dig out my wiring diagrams and see what I can come up with.
What are you trying to accomplish? Is this for an engine swap, or just doing away with a bad ignition switch on a farm truck or...???
__________________
Ah, that makes a difference. There are a few systems we can do away with then...but you're allowed to run EFI? Is it circle track, drag, or what...? (I used to run a mini-stock in circle track racing, but we were only allowed to run carbs, no EFI...)
I'll see what I can come up with...
__________________
For EFI you will need to retain the computer wiring harness, engine sensors, EEC and fuel pump relays. To use a toggle switch, wire it to the EEC relay from a fuse to the battery positive, and the fuel pump contact side of the relay. The EEC relay powers the fuel pump relay coil and the engine sensors and computer. jd
__________________
In memory of my beloved Sandy, 9/28/53 - 1/24/03
