Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 12-18-2007, 06:14 PM
dirtford79 is starting off with a positive reputation.
Arrow wiring q's
ijust need the wires to make it run & thats it id like to run it all off a couple toggle swichs thanx
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 12-19-2007, 06:38 PM
TigerDan's Avatar
TigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud of
Uh...it would be helpful to know what you're working on. What year, carbed or EFI? What engine? With a little more info we can steer you in the right direction.
__________________
FTE Moderator
Stop by and see us in the
Northern California Chapter!
  #3 (permalink)
Old 12-22-2007, 01:39 PM
sorry its a 1991 ranger 2.3l dsi
  #4 (permalink)
Old 12-28-2007, 08:34 AM
TigerDan's Avatar
This can be a little tough...with EFI there are lots of integrated systems, it's not as simple as hooking a up a single hot wire to the ignition on an old-style points-ignition engine. I'll have to dig out my wiring diagrams and see what I can come up with.
What are you trying to accomplish? Is this for an engine swap, or just doing away with a bad ignition switch on a farm truck or...???
__________________
FTE Moderator
  #5 (permalink)
Old 12-28-2007, 04:14 PM
its for racing
  #6 (permalink)
Old 12-28-2007, 06:28 PM
TigerDan's Avatar
Ah, that makes a difference. There are a few systems we can do away with then...but you're allowed to run EFI? Is it circle track, drag, or what...? (I used to run a mini-stock in circle track racing, but we were only allowed to run carbs, no EFI...)
I'll see what I can come up with...
__________________
FTE Moderator
  #7 (permalink)
Old 01-04-2008, 09:35 AM
jimdandy has a good reputation on FTE.jimdandy has a good reputation on FTE.
For EFI you will need to retain the computer wiring harness, engine sensors, EEC and fuel pump relays. To use a toggle switch, wire it to the EEC relay from a fuse to the battery positive, and the fuel pump contact side of the relay. The EEC relay powers the fuel pump relay coil and the engine sensors and computer. jd
__________________
In memory of my beloved Sandy, 9/28/53 - 1/24/03
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
