Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V8 (4.6L, 5.4L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 12-18-2007, 07:10 PM
tjc transport's Avatar
find me if you can!!!
tjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant future
02 5.4 valve tap.
my nephew has an 02 superduty with a 5.4 engine, 100k miles. last month it started a cold valve tap. now it does it almost all the time. is this something to worry about, and is it an easy fix, or just let it be as it is not anything to worry about??
__________________
Join me in the New Jersey Chapter, CLICK HERE!
NEW JERSEY CHAPTER LEADER
Tom
65 falcon 2dr h/t hot 289/C4
66 7 litre 4 speed convertible
79 F250 4X4 plow rig 351M C6
88 superduty diesel 4X4 C6 and banks turbo
99 crown vic P71 interceptor
02 F250 superduty diesel 4X4 stretchcab shortbox, all better now!!
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 12-18-2007, 07:21 PM
LxMan1's Avatar
LxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to behold
You sure it isn't broken exhaust manifold studs causing a ticking exhaust leak?
I would also check the spark plugs asap to make sure they are tight. If one is loose, it will soon blow out and take the threads in the head with it.
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
  #3 (permalink)
Old 12-18-2007, 07:48 PM
nope on the exhaust leak, it is a definite valve tap. and it was doing it before i changed the spark plugs, which i tightened to the specified 11 ft lbs of torque.
__________________
Tom
  #4 (permalink)
Old 12-19-2007, 07:05 AM
LxMan1's Avatar
HMM, this isn't very common in these engines. I thinking that you may have a bad lash adjuster letting the cam follower have too much play.
__________________
88 5.0 LX Mustang
63 F100 351W/C6
  #5 (permalink)
Old 12-19-2007, 09:00 AM
is this something to worry about, or is it a turn the radio volume up kind of thing.
__________________
Tom
  #6 (permalink)
Old 12-19-2007, 05:14 PM
LxMan1's Avatar
As long as the oil pressure is good, I wouldn't worry too much.
__________________
88 5.0 LX Mustang
63 F100 351W/C6
  #7 (permalink)
Old 12-20-2007, 08:29 AM
Joe Finn's Avatar
Joe Finn is starting off with a positive reputation.
Any chance it's an injector ticking? Much more common than a valve and easier to fix too...
__________________
'97 F150 4x4 XLT 4.6L 3.55 LS Supercab
  #8 (permalink)
Old 12-20-2007, 04:26 PM
Quote:
no idea. it is on the passenger side, #3 or 4 cylinder. very loud on cold start, and then quiets down after it warms up. up until 2 weeks ago, it would go away after oil pressure built up.
i have no idea what an injector tick sounds like, but this sounds exactly like my 289 does when the lifter collapses after sitting for a few weeks.
__________________
Tom
  #9 (permalink)
Old 12-21-2007, 12:45 AM
LxMan1's Avatar
Sounds like a bad lash adjuster to me.
__________________
88 5.0 LX Mustang
63 F100 351W/C6
  #10 (permalink)
Old 12-21-2007, 04:46 PM
110octane is starting off with a positive reputation.
tcj
Be careful with this... Check your spark plugs, I had the same type of sound, thought it was an exhaust leak... and let it go for 2 weeks... Just blew the #4 spark plug out of the head. The #4 is hard to get to but check it make sure it's tight. After it happened to me the #3 and #4 are common blowouts... and it rips the threads out... needless to say I'll be removing my heads over the weekend...
  #11 (permalink)
Old 12-21-2007, 06:55 PM
abarreto is starting off with a positive reputation.
I had a similar loud valve tap noise problem with my 02 SuperCrew 5.4 engine when it was cold. I switched oil brand to Amsoil XL two years ago and it cured the problem. I will recomend you to experiment with another brand of oil and maybe this will fix the problem.
  #12 (permalink)
Old 12-22-2007, 07:33 PM
anfo is starting off with a positive reputation.
My 97 made a noise I thought was a lifter or valve but I was told it was piston slap and it went away as it warmed up like you describe. If its the same thing you have its just the short skirt pistons expanding as they heat up and that it was normal for these. NO idea if this is the same or helps, just what I experienced.
  #13 (permalink)
Old 12-26-2007, 12:40 AM
phydough is starting off with a positive reputation.
Old school trick;
Use a dowel or broomstick to your ear and to the cylinder head, inside and out. Try the block, injectors and the valve cover too. This might help localize it further than you already have.
This is partly how I diagnosed a broken piston skirt years ago on a SBC.
My '02 SD sounds horrible at a cold start (below freezing) for almost a minute, like what you describe but goes away.
  #14 (permalink)
Old 12-26-2007, 08:38 PM
elmo8641 is starting off with a positive reputation.
sounds like a bad lifter. find out what cylinder it is and take the valve cover off. check the lifters. i would not let it go.
__________________
2003 f-250sd 4x4 4.10 5.4L
1994 cobra w/ trickflow heads, 10lb turbo
  #15 (permalink)
Old 12-26-2007, 08:44 PM
if it ever stops raining, he is going to bring it over for a closer look. i want to look at the front end also. the last time i saw it it looked like the camber was out on the driver side.
__________________
Tom
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
