Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.8 & 4.2L V6
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 12-18-2007, 05:57 PM
Matt983's Avatar
Matt983 Matt983 is offline
Matt983 is starting off with a positive reputation.
Hurst short throw shifter
This is for Jimmy Dean,
So the shifter was $209.95 from Summit Racing. It wasn't too hard to install the only part I did not like about it was that I had to cut back some of the vinyl flooring to get to 2 bolts and undue the floor cover. The new baseplate covers up the cuts I made. Also the instructions say to drill into the floorboard for the 8 retaining screws around the base plate but I didnt want to put all those holes into my floorboard so I just screwed it into the vinyl till there was no gap.
Also, the only special tool I needed was a T30 torx bit so you might want to make sure to have that on hand before taking everything else apart. All in all it took about 45 minutes with me taking my time and reading directions lol.
PS: the green "Luck of the Irish" band is sold seperatly
So this is what my shifter looks like installed:
  #2 (permalink)
Old 12-18-2007, 06:13 PM
Jimmy Dean's Avatar
Jimmy Dean Jimmy Dean is offline
Jimmy Dean has a good reputation on FTE. Jimmy Dean has a good reputation on FTE.
I take it that the metal plate is supposed to be under the vinyl?
__________________
† - Jimmy Dean - †
02 Sport Reg Cab 2x4 4.2 V6 5 spd (daily driver)
  #3 (permalink)
Old 12-18-2007, 09:37 PM
Matt983's Avatar
No it looks right in the pics the instructions just wanted you to drill holes through the floorboard and sheet metal and then set the screws in that. I didn't want to put all those holes that could fester rust or what not in the floorboard. There is however a second boot cover under the first which is held in by (4) 8mm bolts- 2 of which are hidden way under the vinyl floor mat and the easiest way for me to get to them was to make a 2 inch cut into the floor mat. Once all four bolts are out and you lift out the second boot cover it reveals a hole in the floor exposing the top of the tranny.
The hurst boot cover and polished floor plate cover up where I made the cuts so it doesn't look so tacky lol.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
