80-20 blends with straight oil - Ford Truck Enthusiasts Forums
Old 12-18-2007, 12:28 PM
Finnzo's Avatar
Finnzo Finnzo is offline
Finnzo is starting off with a positive reputation.
Good morning! Any of you guys heard about mixing regular fryer oil (not biodiesel -- undigested, just filtered) at 5:1 with dino diesel? My stepdad tells me he's been doing this for four years with his crapped-out old Merc 300SD and there've been no problems with it other than a more aggressive oil filter change schedule. He told me there was an Idaho State University study that determined that this was A-OK. Now I've found a local source for filtered fish-n-chip sauce for a buck a gallon and I'm thinking about giving it a try.
Thanks!
--Finn
Old 12-18-2007, 02:27 PM
jimmeste's Avatar
jimmeste jimmeste is offline
jimmeste is starting off with a positive reputation.
Check out this web site. These guys are talking about this stuff all the time.
http://biodiesel.infopop.cc/eve/forums
Old 12-18-2007, 08:34 PM
firemediceric's Avatar
firemediceric firemediceric is offline
firemediceric is starting off with a positive reputation.
[QUOTE=jimmeste]Check out this web site. These guys are talking about this stuff all the time.
http://biodiesel.infopop.cc/eve/forums[/QUOTE]
Go to the main sub-forum page there and check out the Solvent Blending forum.
I put 75% WVO in my truck and 85% in my car. Been at it for almost 2 years now.
I've posted plenty here. Search my screen name or just Google it
Old 12-19-2007, 11:30 PM
CanadianSmokie's Avatar
CanadianSmokie CanadianSmokie is offline
CanadianSmokie is gaining momentum as a positive member of FTE.CanadianSmokie is gaining momentum as a positive member of FTE.
I read some research papers from Europe from back in the 80's dealing with blending. Anything more than a 50/50 blend would end up coking the injectors and/or rings. Its a risky way to go...I was doing it with my POS Jetta I had but since switching to a diesel Merc, I won't take the chance....
I did however read an article from a farmer that was working with a chemist and he claimed that adding RUG to the mix (10%) would chemically alter the WVO so it didn't 'string' when tested on an injector bench tester. Lots of opinions... not alot of concrete facts...
Old 12-19-2007, 11:54 PM
Finnzo's Avatar
Well, I might just give it a try -- starting out with a nice conservative 80-20 blend. The thing is, I'm driving a 17-year-old IDI diesel truck. If I had a $30,000 Powerstroke to wreck, it would be a lot harder to justify trying something like this, but with this old 'Binder burner, parts are relatively cheap and the whole truck can be replaced for less than $4,000. I'm tempted to go with a higher mixture and pitch a little gasoline in there to get the viscosity down -- maybe an 8-4-1 gallon mix of diesel-vegoil-gas -- but hey, it's winter -- now's not the time to be taking those kinds of risks.
Cheers! Thanks for the info, everybody!
--Finn
Old 12-20-2007, 11:09 AM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
Speaking as someone with a heavy background in organic and bio chemistry, there is no way RUG will "chemically alter" WVO.
Blending is a crapshoot you are gambling your motor to save a few bucks, it's your decision I will not.
Old 12-20-2007, 04:49 PM
Finnzo's Avatar
Quote:
That's right, it is a gamble. And after spending a couple weeks on research, I've decided I like the odds. They're much better than craps.
Cheers!
--Finn
Tags
blends, wvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
