2004 5.4 washed engine and no start
I took m 2004 F-150 in the mud hole this weekend and now after seeing what my engine looked like I washed the engine with the pressure washer at my complex. Low and behold less than half a mile down the road on my dry out run the engine dies. Now when I try and restart the engine it fires but quickly dies. I had it running for a short time after my tow home but I am still at a battle with this problem. Mind you I put a very large amount of water on this engine due to the amount of mud I saw. But it fired right up and drove about a quarter mile and then just died like I was out of gas. It has been hours and still the same result of the engine starting only for a second and then the quick off. I think I hear when I turn the truck on the noise where you hear your fuel pressure switch kick to pressurize the system wih a click but rather I hear three clicks????? I am at such a loss here. Please help.
Welcome to forum! You are in a special elite group whose first post comes soon after a good engine cleaning. I'd say a disproportionate number of new members come to us because of this issue. Hopefully you only shorted out most of your coil packs. However, being that it won't start at all you may have caused some damage to another important electronic element under the hood. Do you have access to a code reader? Pull the codes and see what you get. You might get lucky and it's only some COP or the issue might dry up.
Never use a pressure washer on these engines. Welcome again, I hope you find the forum useful!
I'm only familiar with two methods: use the travel computer/Message Center (if equipped) to list codes. I think if you hold down the "reset" button and turn the key to "on" it should take you to a special menu that will display the codes as you scroll through the options. The other is to use a scan tool. Most large auto parts stores have them and if you can get your car to one they will pull the codes for free.
Originally Posted by navymech81
I know in GM cars ou can use a paperclip and get flash codes. Can you do this with a Ford? This is my first one I grew up with GM?
Originally Posted by wreedZ71
what does the paperclip do?
