Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 12-17-2007, 09:03 PM
beezf350 is starting off with a positive reputation.
seafom
hey guys i have on 03 f-250 diesel with 120,000 miles on it and it stock i just want to clean her out and get it to run better the fuel mile not so good and just want to know if i but it in the tank will it help clean it up and run better it been about 32 deg outside for the last 2 weeks i live in chicago so On FTE we NEVER use this word or any like it..Admin snow any help would rock guys thank a lot
Matt
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 12-17-2007, 09:06 PM
rollerstud98 is starting off with a positive reputation.
I'd never put that stuff through my diesel, especially not the injectors
  #3 (permalink)
Old 12-17-2007, 09:35 PM
moebdick's Avatar
moebdick is starting off with a positive reputation.
It has alcohol in it. Don't use it in your 6.0L. Try to find some biodiesel and run a little of that thru it, but be sure to cut it down so it won't gel on you. If you can't find biodiesel, go get some Power Service or some Stanadyne.
__________________
2004 F250 Lariat CC, 4X4 PSD
  #4 (permalink)
Old 12-18-2007, 09:26 PM
ok that what i was thinking but you guys say run some bio in it and it will clean it up ?? im trying to find a good way to keep it running clean and running good?? thank and sorry about the first post of the spelling and the words i use i was not all here when i made it sorry guys
  #5 (permalink)
Old 12-18-2007, 09:49 PM
moebdick's Avatar
Quote:
Yes, at concentrations above B5 (5% biodiesel/95% petroleum diesel), biodiesel has solvent properties and will clean varnish and other deposits from the fuel system components. Using B20 or greater in older trucks will sometimes loosen enough deposits to clog fuel filters, so be sure to have extras on hand if you use it.
This is just one way to help keep your fuel system clean. There are others.
__________________
  #6 (permalink)
Old 12-20-2007, 01:49 PM
DSMMH's Avatar
DSMMH is starting off with a positive reputation.
I use SEAFOAM in everything. I normally put a can of Seafoam in every other fill up on the X and I use Lucas injector cleaner when I don't use Seafoam. 58,000 miles with the below mods and no injector or puking problems (knock on wood). Maybe I'm just lucky so far. FWIW!
DSMMH
__________________
04 EXCURSION LTD: 4X4, 6.0L PSD, JUICE w/Tude, Jobe Intake, Elbow Upgrade, ZOODAD, MBRP T-Back, Bilstiens, Hawks, Cryos, Prodigy, Remote Starter, Red OPTIMAs, 30MM Sway Bar, WAAG FB Guard, Dual Steering Stabilizers, Fuel Cross Over Line, PML Tranny Pan, Coolant Filter, 160 AMP Alt Upgrade, LANDYOT Radius Rods and RP Synthetics.
  #7 (permalink)
Old 12-20-2007, 05:38 PM
moebdick's Avatar
Lucas is OK--no alcohol in it. Maybe the amount of Seafoam you use doesn't put enough alcohol in the system to cause any damage. Or maybe it's cumulative. Time will tell, I guess.
__________________
  #8 (permalink)
Old 12-20-2007, 07:50 PM
DSMMH's Avatar
Quote:
Moebdick.......after I read your response I went and read every word on the Seafoam can. I could not find the word ALCOHOL. Now maybe they call it something else but I'm not aware of it. Also, I would be surprised to see a product as popular as Seafoam to knowingly risk diesel damage. The lawsuits would put them out of business.
DSMMH
__________________
  #9 (permalink)
Old 12-20-2007, 08:43 PM
elee3 is starting off with a positive reputation.
I don't have a dog in this fight, but I searched the web for seafoam ingredients, and apparently it contains isopropyl alcohol, which is the same as rubbing alcohol.
  #10 (permalink)
Old 12-20-2007, 10:13 PM
msgtg's Avatar
msgtg has a great reputation on FTE.msgtg has a great reputation on FTE.msgtg has a great reputation on FTE.msgtg has a great reputation on FTE.msgtg has a great reputation on FTE.
I've used it in my gasser (a 351 in my 92 F150) with great results. I'd be hesitant to try it in my 6.0 though. I do use DK at every fillup. I've changed over to the white bottle now that the temps are below 35. The white bottle has anti-gel, the grey does not.
Joe
__________________
MSgtG
Chapter Lead - West Virginia
JOIN THE WEST VIRGINIA CHAPTER CLICK HERE
2009 MIDATLANTIC MEET, CARLISLE, PA ALL TRUCK NATIONALS AUGUST 7--9, 2009 CLICK HERE
03 F250 King Ranch Crew
We live in the Land Of The Free...BECAUSE of the Brave! My humble thanks to all Veterans, past and present
  #11 (permalink)
Old 12-21-2007, 12:25 AM
blackhat620's Avatar
blackhat620 has a great reputation on FTE.blackhat620 has a great reputation on FTE.blackhat620 has a great reputation on FTE.blackhat620 has a great reputation on FTE.
Here is the link to the MSDS for Seafoam,
40-60% Pale Oil
25-35% Naptha
10-20% IPA (Isopropal Alcohol)
www.seafoamsales.com/pdf/MSDS_SFTT_US.pdf
Do Not use any fuel additive that contains Alcohol, the alcohol will damage the injectors.
__________________
Courage is being scared to death---and saddling up anyway.
-John Wayne-
06 F350 CC SB 6.0 4x4, Suburban Ford (Thanks Ernie )
04 F350 CC SB 6.0 4x4, Van Bortel Ford (Thanks Jeff ) [Traded 05/2006]
  #12 (permalink)
Old 12-21-2007, 06:10 AM
moebdick's Avatar
A number of diesel fuel additives contain alcohol. Power Service 911, for example. It's used to solubilize moisture, prevent gelling and de-ice fuel lines and filters. I guess it may clean things a little as it goes through the system, too. I'm not sure exactly what alcohol will do to a diesel engine, but it apparently lowers the flashpoint and burn characteristics of the fuel somehow. Since injection timing is based on a given fuel flashpoint and combustion duration, alcohol can throw off the combustion timing or something. Burns hotter, too. Good for racing I guess.
I doubt occasionally using 2 or 3 ounces of alcohol per tank would do any damage, but I really don't know. My engine manual says don't use alcohol in the fuel. That's why I told Beez not to use Seafoam. I knew it had some alcohol in it and there are plenty of diesel fuel additives that don't.
__________________
  #13 (permalink)
Old 12-25-2007, 01:16 PM
slisty is gaining momentum as a positive member of FTE.
I would find and run Bio. I live near Chicago and you can find it just takes some time. If this will be the first time you have ran it plan to change your fuel filter after a tank or two.
__________________
2005 F250 SD, Lariat, crew cab, 4x4, 6.0L
4" Silverline Turbo back exhaust, SCT Xcal2, EGT temp Trans temp and boost gauges, Stage 2 intake, and other HMP mods.
Some call it a peace sign, I call it the foot print of the american chicken!
ILLINOIS Chapter Leader 2006 to Present.
  #14 (permalink)
Old 12-25-2007, 01:41 PM
wrangler76 is starting off with a positive reputation.
I use Seafoam in the fuel tank of gas engines it was created for... I use Biodiesel at upto 20% in my diesel especially after the Ultra low sulfer #2 came out.
__________________
Adam
Carson, WA
"Meller Yeller" - '79 F-350 4x4 Supercab, Built 356 series
'04 F-250 4x4 Supercab, 6.0 PSD
  #15 (permalink)
Old 12-25-2007, 02:14 PM
4x4Mark is starting off with a positive reputation.
Like Blackhat said, its not good for the injectors. If I remember right, the alcohol absorbs moisture, and then when that hits the injectors, it can destroy them due to the high pressures/temps.
Many may have gotten away with additives with alcohol, but possibly due to your fuel being free of water. I think Power service 911 is meant to deal wi a problem where your fuel is already solidified, and not a preventative measure.
Mark
__________________
2004 White F350 XLT, CC, SB, 4x4, 6.0L Auto, 3.73LS, Camper Pkg, Skid Pkg, Edge 2" Mini Spring Pack, Bilsteins, MBRP exhaust, Coolant Filter, FluidAmpr, Elite Regulated Return (55 psi), Airdog
Built: 11/03/03
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
