12-17-2007, 08:29 PM
> once my wiring gets screwed like it is it is very hard to get it running right again.
No, just replace all the fusible links and relays, which you probably have to do anyways and replace the harness from a donor vehicle. I would just go to a junkyard and grab all the electrical I could.
Just make sure the harness that runs across the front and near the battery isn't rusted away from the donor vehicle, which it shouldn't be in your state.
