Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Engine Swaps
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 12-16-2007, 09:55 PM
Madmike33's Avatar
Madmike33 is starting off with a positive reputation.
302 Starter hook up in my Ranger
Ok guys,
Here I am in the final steps of the 302 swap and here's yet another issue. The 302 is from an 88 F150 EFI (converted to carb)
Allright the starter on my ranger had 3 hookups, one 12 guage from the solonoid, on 4 gauge positive from the battery, and one negative.
The starter on the 302 has 1 place to hook up on the starter, why? I'm thinking it's a positive hook up, but I hook it up from where, and what guage? Logic tells me, I should use the wire from the solonoid(at the fender) but a 12 guage alone seems small for a starter. What about a ground? shouldn't I ground the starter, if so where? There's only the one hook up, unless I just hook up a ground on one of the mounting bolts, would that be a good idea?
I need your help guys.
Thanx,
Madmike33
__________________
Madmike33
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 12-17-2007, 11:31 AM
krewat's Avatar
krewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud of
You should get a solenoid (the "relay" on the fenderwell) from whatever vehicle the 302 came out of.
Then run a large-gauge wire from the solenoid to the starter.
The original starter has a solenoid ON the starter. The 302 starter does not. You need a heavy-duty solenoid for the fenderwell, run a heavy gauge wire from the battery to the solenoid, and then from the solenoid to the starter, and everything should be fine.
__________________
- art k. - Moderator for the Superduty, V10, and FE forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 Volant CAI, eBay headers and y-pipe
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased!
I've been wrong before, I'll be wrong again. Just wait and see.
  #3 (permalink)
Old 12-17-2007, 09:24 PM
projectnitemare is starting off with a positive reputation.
Exactly. Go to any autopart store and ask for a fender mounted starter solenoid. If they are too dumb to know what that is, say a starter solenoid for an 88 Ranger. You will need to run the small wire, (red with blue stripe) to the solenoiod. Then you will need a battery cable to go from positive to the solenoid, then one from the solenoid to the starter. Your ground needs to go to both the frame and the engine.
Matt
__________________
88 Ranger XLT 4x4, 396W stroker, ZF 5 speed, twin stick NP 205, Perry's Fab n' Fiber fenders & bedsides and hood, 8.8 swap, BII gas tank, lifted a bit, 35in ProComp M/Ts.....4 linked Rockewells and supercharged 557 on the way
  #4 (permalink)
Old 12-18-2007, 01:15 AM
Madmike33's Avatar
Thanx guys, sounds good. I still have the truck the 302 came out of its up north but only about 1 hours drive. I knew I should have grabbed that when I was tearing into it.
Thanx again guys.
Madmike33
__________________
Madmike33
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
